I have a GA-K8NSC-939 Motherboard which was working fine before moving into a new tower,
Now the MB stays on when PSU is switched on, only shuts down if PSU is manually turned off,
It will not boot up so no way of getting into bios, tried clearing cmos jumper, removed battery,
Made sure nothing is shorting out, tried removing from the case hooking up out of case still same issue, I have tried 3 different PSU’s same issue so am thinking must be in MB, the MB is 20 pin and PSU’s are all 20+4 shouldn’t make a difference, I even tried without anything connected except video card, this is driving me crazy, never had this issue before hoping to find a solution here.
MB is a GA-K8NSC-939 with an athlon 64 CPU, 2GB Kingston HyperX DDR400, Radeon video card 256MB, any help advise or suggestions would be appreaciated.
Thanks
Thanks
