Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Making Ultra X2 power supply modular cables
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Making Ultra X2 power supply modular cables
Hi, everybody. As you all can see, I'm a novice in this forum.
Well, I have a PSO Ultra X2 550 watts but when my uncle brought it from usa, Modular Cables weres lost at the airport along with other things.
I've noticed that the modular connections source, are identical to the connections of the peripherals, which make me think that I could do cables from power supplies already damaged. Tell me if is possible and if so, would be point to point connections or a different configurations (such as crossover cable, for example).
I know you would say it's easier to buy, but I don't have a way and here in my country stores do not sell it.
Thanks for the help.
Sponsored Links
If you can get the connectors, making the cables requires only rudimentary soldering skills.
Reply to jsc
Yes, jsc.. you're right. I have experience in soldering but, I need to know if cables are in a special configuration (like some cables which are crossover, point-to-point...).
I mean if it must be same way in each conector.
Reply to el_lujo
Forgive me if I being ambiguous. The problem is that I don't have any cable to see how it's configured via conector to conector.
Reply to el_lujo
Why don't you go to the ultra website and contact them for info. They may be able to send you some spares.
Reply to o1die
There are 1224 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
