Tom's Hardware > Forum > Homebuilt Systems > New System Build > Will this system be able to OC to 4GHz
Forum Homebuilt Systems : New System Build - Will this system be able to OC to 4GHz
I have been reading a *** ton of articles about people OCing there i7 920 to 4GHz and was wondering if y'all think with this setup:
COOLER MASTER HAF 932
GIGABYTE GA-EX58-UD4P
Intel Core i7 920 - D0 Stepping
OCZ Platinum 6GB (3 x 2GB) DDR3 1600MHz
CORSAIR CMPSU-850HX
OCZ OCZTFRZTC Freeze Extreme Compound
Thermalright Ultra 120 eXtreme - 1366 RT
This is an aircooled system, just wanting to know if you think i will be able to achieve the desired benchmark?
------------------------------ You are not even my son. You are a Bastard from a Basket. Go wave your damn hands around somewhere else.
Sponsored Links
You have a good shot at it with your set up. The Ultra is a great cooler and the HAF 932 has very good air flow to...
Good Luck!!
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
There are 553 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
