Solved
Will this CPU cooler fit with this motherboard and case?
25 answers Last reply Best Answer
More about will cooler motherboard case
  1. And is there any cheaper CPU coolers that you guys would reccomend processor is getting too hot at 100% load it's 62C
  2. AMD phenom 925
  3. Well the Thermaltake Frio is 6.5 inches in height and the Rosewell case is 7.90 inches in width so yes it should fit but it looks like you can install a fan on the side of the case so if you wanna put the fan on the sidepanel then no it won't fit...But it will fit without the side fan...Do you already have that case because it shows it's discontinued in newegg?
  4. Also at 100% full load 62c is fine...Are you running prime 95? If not what are you using to make your cpu at 100% full load? When im gaming and surfing the web im not even at 100%..Are you talking about just in normal load in general or prime 95 temps? If those are prime 95 temps then those are fine...
    Also the Cooler Master Hyper 212 plus is the best heatsink for it's price..
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
    Yes i already have that Case, so would that CPU heatsink block my ram slots?
    Prime 95 Temps
  7. Any other recommendations of CPU coolers oh and btw how would i make it so all my fans are connected to like 1 connector?
    it depends if you get high ram heatsinks...it should work fine with normal size ram...But you might wanna double check...Get the Cooler master hyper 212 plus heatsink its just as good at the frio for a cheaper price..
  9. I have G Skill Ripjaws so I should be fine to keep using stock HSF for a little while because i've been using almost all 4 gigs of my Ram
  10. Is the Arctic cooling Rev 2 92 MM Cpu heatsink a good heatsink?
    should be better then what you have now :)...but 92mm will probably make your case loud...
    Ok because I found it for 27.98 on newegg and it seemed like a good CPU heatsink also if i have g skill ripjaws 1600 does that mean i should get another set because if i go with a different brand it will be cheaper
  13. Best answer
    how much ram are you using? the most i'd go honestly is 8gigs...you can get single sticks with 4gigs each so 2 sticks would be 8gigs...But 4gigs for now is more then enough imo...
    Also here's a pretty decent heatsink for $25
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835233081
  14. I was looking at that but, i didnt know if my case had enough clearance. And im running 4 GB right now 2x4 and i run 3 dark age of camelot accounts and almost use all of it when everything is said and done i have like 400-500 MB left.
  15. and can I make it so like all my fans are connected into 1 wire because my motherboard has 2 fan slots only a 3 pin/4 pin
    how many fans do you have total?
    they sell fan splitters also you should be able to connect some of the fans into the power supply with a fan adapter...for your cpu you can get a cpu fan splitter that connects to 2 fans and connects to the cpu fan connector on the motherboard...
    here's a example..
    http://www.newegg.com/Product/Product.aspx?Item=N82E16812200855&cm_re=cpu_fan_splitter-_-12-200-855-_-Product
  17. I have 3 fan's but can only currently use 2 my back exhaust fan and the CPU fan and i have one near the hard drive tray but I cant use it and i wanted to get a nother one for the xigmatek loki since it's so cheap which fan would you reccomend getting so i can have a push pull setup
  18. The cpu header is a 4 pin..
  19. casey10 said:
    yes it should work...
    as far as fans i usually go with Noctua or Gelid wings since they are very quite...But they are expensive..
  20. Do I have to connect this one to the PSU though?
    you can connect it to the motherboard or psu...
  22. Thank you for all the help bigmac
  23. Best answer selected by casey10.
Heatsinks CPUs Rosewill Cooling Motherboards Cases Overclocking Product MSI-Microstar
