Tom's Hardware > Forum > CPU & Components > CPUs > AMD PH II x3 720 cooling solution
Forum CPU & Components : CPUs - AMD PH II x3 720 cooling solution
I do not know the first thing about aftermarket CPU cooling. I read the different size of the CPU makes a huge different on what kind of aftermarket cooling product you purchase. Can you please help me find a nice affordable cooling solution for my new AMD PHENOM II x3 720 2.8 Ghz socket AM3 95w Triple Core processor.
Link - http://www.newegg.com/Product/Prod [...] -_-Product
I was also wondering how over clockable this processor is and how difficult the process would be having never done over clocking before. And does properly over clocking a processor shorten the life of the CPU?
Sponsored Links
http://www.frostytech.com/articlev [...] cleID=2348
you can find it at amazon
btw, clips right on to amd bracket, no back plate
Message edited by xaira on 09-19-2009 at 05:43:38 PM
------------------------------ "Envy is ignorance" - Henry Thoreau : Best quote ever.
http://www.pingtest.net/result/3022953.png
Reply to xaira
HDT-S1283, Sunbeam CCF, Mugen 2 are all great for the price. Get Megahalems or a True if you're budget allows.
Reply to ShtBrix
There are 1094 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
