8600GT problem
Forum Graphic & Displays : Graphics Cards - 8600GT problem
Hi All
today i picked up a m2n68-am se2 motherboard (http://www.ebuyer.com/product/167433) and an inno3d 8600gt gfx card.
But i cant seem to get the dam thing to work(8600 gfx card that is). downloaded the latest drivers from nvidia and tryed turning the onboard gfx off via bios and device manager, but still nothing. when the card is plugged into the pci-e 16 slot the fan is working but the monitor just stays on standby?
any help would be much appreciated.
Sponsored Links
Nbull wrote :
Hi All
does your onboard work?
It your power supply in good or bad condition(how old is it, is it cheap or of good quality) at least 350 watts?
do you hear ne beeping when you start the computer?
are your power connectors plugged into the GFX card?
try a new DVI or VGA cable
hope this helps, plz update
Uber :D
------------------------------ “Not only does God play dice, but... he sometimes throws them where they cannot be seen.” -Stephen Hawking
Reply to UberGenocide
thanks for the fast response.
The psu is new, 500w
when the 8600gt is plugged in, it beeps several times but nothing happens, screen stays on standby
Not sure about power connectors? never had them plugged in before?
machine is working as im on it atm, but with crappy onboard gfx :(
Reply to Nbull
i also tryed my old 8400GS and that did excatly the same. monitor just stayed on standby.
Reply to Nbull
do those cards work in ne other computer
Several beeps mean a video or power problem nad your 500 is plenty to power a 8600 GT(my 550 powers my 260 GTX full load)
Idk y but try one stick of RAM, i had a similar problem and it turned out that a RAM stick was bad(i too had several beeps)
If that fails, try a new PSU, that one may be defective and not juice your PCI video enough to get signal to the monitor
Uber :D
quick edit- if that paticualr stick of RAM doesnt work, try different sticks :D
Message edited by UberGenocide on 07-08-2009 at 02:49:07 PM
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 8600GT problem
There are 1019 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
