Tom's Hardware > Forum > CPU & Components > CPUs > I5 750 vs. i7 920: The real power consumption diff
Forum CPU & Components : CPUs - I5 750 vs. i7 920: The real power consumption diff
Tom's test shows that Core i5 750 + LGA1156 draws 60W less then Core i7 920 + LGA1366 at full load. Since the test is done during CPU full load, then I guess that the i7 is using all of it's virtual 8 cores during the test, while i5 is using only 4 cores.
This looks like a major power difference for pieces of hardware that do about the same performance in most cases. However, the big difference in performance is on applications that uses the i7 hyper-threading, in which case the 920 may be 20% faster then the 750.
Now, I've found some results that shows that an i7 920 based system uses 70W less power when running 4 threads comparing to 8 threads.
This means, that Core i5 750 + LGA1156 draws about the same power as Core i7 920 + LGA1366 and has about the same performance when running 4 or less threads. The 920 is using more power when running more then 4 threads, but then it delivers much better performance.
My conclusion is that power efficiency is not one of the reasons to choose i5 over i7. What do you think ?
Message edited by yanival on 09-20-2009 at 03:10:21 AM
Sponsored Links
To be fair, I think the i7 860 should be compared to the 920, so that HT is included in both's TDP.
Reply to sanchz
Choosing LGA1156 vs LGA1366 is that X58 will get the i9s (hex core with 12 threads) while P55 will not.
I don't really care much for power consumption. At any rate, i7 (920,etc) is easier (as in no need to increase voltage much,etc) to OC according to a few reviews.
Below pretty much sums up what I am thinking:
Quote :
My recommendations from the initial Lynnfield review still stand, you'll want to opt for Bloomfield processor if you care about:
1) High-end multi-GPU performance (or other uses of high bandwidth PCIe)
2) Stock Voltage Overclocking
3) Future support for 6-core Gulftown CPUs
http://www.anandtech.com/cpuchipse [...] i=3641&p=9
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
I would hope the i5 and the new lga1156 i7s would use less power than the i7 920. 95w vs 130w.
+1 to sanchz. Compare to the i7 860 if anything.
Reply to someguy7
- 0 +
I do agree, the power consumption comparison should be between i7 920 and 860. However, those two processors are in different price scale. Most of the user will probably wonder between the 750 and 920.
Reply to yanival
- 0 +
OK, but comparing 860 to 920 will give you "clean" results of 95w 2.8GHz vs 130w 2.66GHz; both with HT, and the 860 with Turbo Mode. Thins way, you get to know if the 860 really is much more efficient (35w less, 200MHz more, higher Turbo modes).
Anyway, the i5 should consume less than an i7 920 with HT off, yet the 920 might have tighter power requirements than i5, so that the 920 without HT consumes less power than i5 which has more "loose" TDP requirements.
Reply to sanchz
Im pretty sure intel is going to release a low power 860s like they did with the 9550s soon.
Reply to mpavao81
Considering that HT can add another 10C to your temperatures pretty easily it's not surprising that it increases power consumption substantially.
Reply to randomizer
There are 1014 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
