Hi guys, I recently bought a brand new setup and tried to overclock it for the first time. Now I am completely new to overclocking, but I spoke to a friend who said with the setup i should be able to achieve very high overclocks with ease. My setup is as follows:
CPU: i7 2600k
CPU Cooler: Coolit ECO ALC
Motherboard: Asus P8P67 Pro
Graphics: Radeon HD6950
RAM: 8GB Kingston Hyper X Genesis 1600
HDD: 80GB SSD Intel 310 series, 1TB WD Caviar Black
PSU: Corsair TX650
Case: Antec 900
I tried to overclock to 4.2Ghz however using prime95 my core temps shot up to above 80C. I reduced this to 4.0Ghz but the temperatures under load is still 70C or so. Judging by what others have said these temperatures seem very high.
Also because I am new to this I dont understand the difference between Tcase and core temp, the Tcase for the i7 is 72C or so, but does this greatly differ from the core temp?
I am at work at the moment but plan to restore to defaults and monitor the temp then, both idle and under load, and will post as soon as I can. In the meantime any suggestions or advice would be greatly appreciated. Also if any additional info is required please let me know.
Thanks in advance,
Dan.
CPU: i7 2600k
PSU: Corsair TX650
Case: Antec 900
Thanks in advance,
Dan.
