Hi, this is my first time posting on this website. I was just wondering if these specs will work and do good together for my first water cooling setup!
- EK-Supreme HF High Flow - CPU Water Block
- Black Ice® GTX Gen Two Xtreme 360 Highest Performance Radiator
- Primochill Myriad D5 Dual Bay Reservoir / Pump Housing( I will be putting a Swiftech MCP655 pump in there)
- PrimoFlex Pro LRT UV Blue Tubing -1/2in. ID X 3/4in. OD
- Feser One F1 Cooling Fluid - Clear/UV Blue
I will be using all rotary compression fittings by Bitspower, either normal, 45 degree, or 90 degree
This will be cooling a i7 2600k and a EVGA GTX 590 Hydro Copper
Hows this sound? Give me any feed back on what i might be able to do different or change to make this better
