This is driving me nuts.
Phenon II, 955, Black edition
Asus M4A785TD-M EVO
2x2gb Patriot PC3-12800, 1600mhz memory.
CPU-z says:
Channels = Dual Channel
NB Frequence = 2008 mhz
Dram Frequency is 535.7mhz
7-7-7-20-27
SPD Slot 1
DDR3
Module: 2048mbytes
Max Bandwidth: PC3-8500F (533mhz)
Part #: 1600EL series
Jedec #1
457
6-6-6-18-24
Jedec #2
533 mhz
7-7-7-20-27
Slot 2 is the same as slot 1
mothrboard says it supports DDR3 up to 1800mhz O.C, but all the numbers below that it says without OC. So I don tknow why the memory isn't working at, at least 800mhz?
something im suppose to do in the ASUS mobo settings? Everything under Jumper Free configuration is on Auto.
Main Page of CPU-Z
Core speed = 800 mhz (it down scales)
multiplrer x 4
bus speed 200mhz
HT link 2000mhz
this is just frustration because 533 means 1066 effective, feel like im not getting the max performance for what i payed for? Even though I dont think i would feel the difference, i want it to show me the correct numbesr though!
Asus M4A785TD-M EVO
CPU-z says:
7-7-7-20-27
SPD Slot 1
DDR3
Module: 2048mbytes
Jedec #1
457
6-6-6-18-24
Jedec #2
533 mhz
7-7-7-20-27
Main Page of CPU-Z
multiplrer x 4
bus speed 200mhz
HT link 2000mhz
