Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Need help picking out power supply and card
Forum Graphic & Displays : Graphics Cards - Need help picking out power supply and card
Hello,i recently bought an hp.the graphics arent too bad,but at the same time arent that great..
Can anyone reccomend me a power supply + a graphics card?
here are some of my specs
Processor - Intel(R) Pentium(R) Dual-Core processor E5200 [2.5GHz, 2MB L2, 800MHz FSB]
it came with a GeForce 7100 nForce 630i motherboard/graphics
3GB DDR2-800MHz SDRAM [2 DIMMs]
Power supply 250 watts
Total slots 1 PCIe (x16 graphics), 1 PCI, 2 PCIe (x1)
so what would be my best route considering i would like to spend no more than a total of 300$?
Sponsored Links
4870 1GB $129 after rebate
http://www.newegg.com/Product/Prod [...] 6814161269
Antec 550w SLI/Crossfire $65
http://www.newegg.com/Product/Prod [...] 6817371016
if you have a monitor larger then 24 inches you can jump up to an ATI 4890
*save the extra $100 for a future CPU upgrade
Message edited by ct1615 on 07-08-2009 at 08:04:44 PM
Reply to ct1615
- 0 +
Is this a slimline or 'normal' case?
What are your doing with this system?
------------------------------ Peace cannot be kept by force, it can only be achieved by understanding: Eienstien
Reply to coozie7
This is a normal case.and i bought this computer mainly for using it as my home recording studio,but i couldnt resist using it for internet and now i want to also play games on it.i bought a 20$ war game and it looks slighty choppy.i plan on playing games on it maybe 10 hrs a week tops..
i am using a 17inch westinghouse lcd and maybe in a few months i will start using a 42 inch lcdtv..
so i kind of want something that will be equally as great on both screens if possible.
thanks guys you are both real helpful.ive spent hours looking online and i havent been able to get nowhere until i found this board
Reply to droneout
the computer is al pavillion 6110t
Reply to droneout
- 0 +
With a E5200 and set to stock clocks a HD4870 is going to be heavily restricted, the CPU simply cannot feed it with enough data this is a little more appropriate:
http://www.newegg.com/Product/Prod [...] 6814161252
And because the card needs less power you can use a less expensive, but still quality unit:
http://www.newegg.com/Product/Prod [...] 6817371023
Neither of the above are Godspel perfect for you and depend on the TV you're using. If it's 1080 you might want to look at the HD4770 or 9800GT class which are a step up from the HD4670
Message edited by coozie7 on 07-08-2009 at 08:50:20 PM
Reply to coozie7
Given how small your display is you will be ehavily CPU limited as coozie has stated. No need to get something as powerful as a 4870 until you use a bigger display. The CPU will hold you back, and even with a fine CPU a 4850 would be the most you'd ever need for that resolution.
The CPU is not as much a factor if your TV is 1080P, while a 4850 would be sufficient still. you would notice the upgrade to a 4870 at that point.
Regardless of a "bottleneck" you wil still get mroe performance out of a 4870 when comapred to slower cards.. it just would be of questionable value for your money. As you increase the reolution it becomes less of an issue.
------------------------------ CPU: Q9550 at 3.6ghz (FSB 425mhz) | MB: P5E3 Premium | Ram: 4*2Gb Corsair DDR3 @1417mhz | GPU: 2 HD4890 1Gb (925core/1025mem) CF | PSU: OCZ ELiteXtreme 800W | Sound: Creative Titanium Fatal1ty Pro | 2*120gb OCZ Vertex SSD Raid0 and 2 500gb Raid0 HDDS
Reply to daedalus685
- 0 +
the e5200 is still a decent CPU and could be OC if not for the fact the PC is a HP
http://www.bit-tech.net/hardware/c [...] c-review/4
Reply to ct1615
Regardless of what you do a new PSU would be required for a new GPU.
Aye, even at stock it is still an alright low end CPU. Only at CPU limited resolutions, like most 17" displays would give you, is the 'bottlenecking" much of an issue.
hmm so anything between the 4670 and 4850 im guessing?
what brand should i go with? there is various ones i have come across
Reply to droneout
- 0 +
asus, xfx, his, msi, gigabyte, sapphire are some of the better ATI manufacturers
Reply to ct1615
thanks guys i really appreciate it
Reply to droneout
- 0 +
I have a couple of the HIS cards; a 4850 and a 4670. The IceQ4 cooler is very effective and very quiet.
Antec is a solid PSU brand, but I'd look at an Earthwatts over a BP for higher quality and better efficiency.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
is there any risk of damaging my computer by changing the power supply?
rookie question haha
Reply to droneout
- 0 +
Mechanically, yes, the motherboard connectors can be tight risking damage if you are a little clumsy and some wires may be difficult to reach or require the removal of the CPU cooler or cooler ducting.
Take it slowly and carefully and you will be fine.
It is not possible to put the wrong connectors into the wrong sockets.
All power supplies provide standard voltages, so there's no risk of electrical damage either.
Reply to coozie7
one last question for you pc gamers..
Should i settle for the 512mb SAPPHIRE HD 4670
or go for the 1gb? is it a huge difference?
Reply to droneout
- 0 +
the card is too slow to take advantage of 1GB, there will be no difference if you get the 512mb
Reply to ct1615
A GTS 250, 400w PSU from corsair <--- Very Affordable
Message edited by stevensl2 on 07-11-2009 at 09:37:26 AM
------------------------------ Core I7 920 @ 3.66ghz | Xfx 4870 1gb Tri-Fire | DFI Lanparty x58 UT | G.Skill Trident 3x2gb @1834mhz | Asus Xonar Dx | Coolermaster Ultimate 1100w | Coolermaster Storm Sniper case | BenQ E2400HD 24inch 1920x1080 | Thermalright TRUE Push/Pull Fan |
Reply to stevensl2
so what happens to the stock card when i install the new one?
am i supposed to disconnect the wire to that one and connect the new one? im kinda confused about that.lol
Reply to droneout
- 0 +
you have integrated graphics currently so there is no card to remove
simply locate your PCI-E x16 slot, plug your new card into it with the PC off
connect your monitor to the cards port
turn on your PC
Install the drivers (down load latest from the ATI web site)
Reply to ct1615
- 0 +
Hey just wanna ask a question relating i am about to buy a new graphics card and PSU iv got around 140-200 Australian to purchase with any thoughts i what i should get
i was thinking the Ati 4650 1 gb from asus and the A-Power 750w dual fan PSU
my system is
Intel Pentium 4 3.00 ghz
1.2 gig ram
40gig Internal hard drive
80gig external hard drive
intergrated graphics card
windows XP
this will be mostly used to play wow , and newer games
Reply to maxll3
There are 1172 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
