SSD - The Performance Upgrade of the Future
I am wanting to upgrade my graphics card but i have no idea if it will fit my 16x slot contacting gateway has been next to useless so i thought i would try here. I have a gateway fx530 which uses the now dead btx case/motherboard.
Welcome to the forums! It will not fit IMHO. You need a shorter card. Dimensions: 260x100x33 mm (the last figure is the maximum thickness) Make sure your power supply supports the card you want. You can check back here on that.
Please double check me by measuring inside the case.
Try a 4670 or 9600gt Low power
