Tom's Hardware > Forum > Homebuilt Systems > New System Build > Need advice on $500 to $700 build
Forum Homebuilt Systems : New System Build - Need advice on $500 to $700 build
I'm planning to build my first computer soon. I've done a lot of research and this is what I've come up with. I think I've come up with a good value build that has some good power, but I wanted to see what you guys think of it. Does this build seem balanced? Does anything stand out as not being a good fit? Any advice would be appreciated.
Just FYI, my objective has been to keep my build around $500 to $700, and to end up with a computer that has good upgrade potential and good all around ability to handle games and media.
So here's what I've come up with:
Case: Cooler Master RC-690
http://www.newegg.com/Product/Prod [...] Tpk=rc-690
Power Supply: Corsair 650tx
http://www.newegg.com/Product/Prod [...] &Tpk=650tx
Motherboard: Gigabyte GA-MA790X-UD4P
http://www.newegg.com/Product/Prod [...] 6813128387
CPU: Phenom II X3 710
http://www.newegg.com/Product/Prod [...] 20x3%20710
GPU: Sapphire 100259-1GL Radeon HD 4870 1GB
http://www.newegg.com/Product/Prod [...] 6814102801
RAM: OCZ Reaper HPC 4gb
http://www.newegg.com/Product/Prod [...] 6820227289
Hard Drive: Wester Digital Caviar Black 500gb
http://www.newegg.com/Product/Prod [...] 6822136320
Optical Drive: Samsung Black 22XSH-S223F
http://www.newegg.com/Product/Prod [...] ck%20s223f
Any thoughts? Are there any obvious incompatibilities that I'm missing here? Are there any bottlenecks that I should be aware of?
Thanks in advance.
Sponsored Links
looks like a solid build. For $700 it looks like you're squeezing as much in as you can.
I dont think i'd change anything actually, just make sure that you put the GPU in the 2.0 x16 slot that is running at x16 (one is running at x8)
Reply to thefox14
$5 more can get you the 640GB caviar black.
What resolution are you playing at... if its on the lower side, you can get the 512MB 4870 instead, there is one going for as low as $125 on newegg.
http://www.newegg.com/Product/Prod [...] 6814131140
Don't know how long that deal is going to be available.
You can probably get a cheaper 4GB memory kit and spend the savings on the Phenom II X3 720BE instead... slightly higher clocks, and easier to overclock.
Otherwise, you're good to go.
Reply to kevin1212
Cheaper RAMs
OCZ "Fatal1ty" DDR2-1066, $50, $10 MIR
Cheaper, lower-performance. Looks sick, though.
http://www.newegg.com/Product/Prod [...] 6820227364
Crucial Ballistix, DDR2-800, $40
http://www.newegg.com/Product/Prod [...] 6820148212
------------------------------ Phenom II X2 unlocked to four cores @ 3.8gHz,1.45V. 4GB DDR3-1600 Gigabyte 785g ATi Radeon HD4870 1GB
Run Folding@Home! Support Toms Hardware Guide, Team 40051!
CPU Buyer's Guide
Reply to smithereen
Thanks a lot for the feedback. I really appreciate it. I'll definitely take these suggestions into consideration.
Reply to Xangalore
There are 1127 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
