My current case is a Cooler Master Centurion, I am forget the exact model but it is a discontinued mid tower, and I have noticed that with the size of my 4870 graphics cards, the air from the single 120mm intake fan does not have a chance to move up through the gap between the graphics card and the drive bays. This means that my current heatsink, a setup with the fan on the side, is not getting sufficient airflow. There are vents above my cpu for an intake for a vertical heatsink, but these do not provide as much cooling. I need to know whether adding an exhaust fan to the rear of my case (I currently don't have any) would alleviate this problem, or do I need to change my heatsink for one with a fan on top?
I have a Centurion 590 adding 2 exhaust fans to the top blowholes will seriously improve cooling, it would help advising you if you knew what Centurion model you have in your possession.
------------------------------Badges? We don't need no stinkin' badges!
Reply to 4ryan6
I'm not sure, but the exhaust fan at the rear of the case really helped. My centurion is quite old, so I don't know the model # but it doesn't have any ventilation on the top.
