Since there are so many benchmarks about power consumption of graphics cards and sometimes there are big gap between the result from one benchmark to another. So I decided to do some maths...
with these conditions:
a) Samples are taken from 17 benchmarks results which means different brands and system set-up
b) To narrow these gap and for safe guidelines:
- Only benchmark of total system power consumption under heavy load (not idle) are used
- The average of power consumption are taken from 3 benchmark with the higest results
[ie: benchmark result of 4850= ...227-252-269-271-276 Watt, then the average is: (269+271+276)/3]
And the result:
Type = Average [ATI PSU Recommendation]
4670 = 212 Watt [400 Watt]
4770 = 243 Watt [450 Watt]
4830 = 244 Watt [450 Watt]
4850 = 272 Watt [450 Watt]
4870 = 340 Watt [500 Watt]
Hope this can help those who wanna upgrade their graphic card but worrying their psu capabilities and dont want wasting too much time to check all those benchies
A lot depends on the quality of the PSU. An Antec Earthwatts 380W will run a 4670 24/7 month after month; I'm doing just that (it should also handle up to a 4850, but that combo I haven't used personally). OTOH, a cheap PSU will croak long before it gets anywhere near its labeled output: http://www.corsair.com/cinema/movie.aspx?id=622747.
