Looking for a replacement external enclosure power supply
Last response: in Storage
a b ) Power supply
March 7, 2011 9:06:33 PM
Simple one really.
I've been googling but have come up with nothing under £20 ¬_¬.
I'm looking for 12v / 5v power supply adapter for an external enclosure. My external drive's power supply has died after a power cut, I know the drive is fine because I have a second enclosure (identical) and it works just fine using that power supply.
The powersupply has a UK mains plug to kettle lead, plugged into the transformer, then the transformer has a 2-pin that goes to a 6-pin round plug that goes into the enclosure itself.
I can't seem to find a replacement power supply and would prefer not to buy two new enclosures to keep them matching.. that could easily cost £30+ when I'm sure a power supply would only be £5 if I could find it.
Any help would be great.
Ace.
