Case Help.
Forum Homebuilt Systems : New System Build - Case Help.
G'day,
Here's my Delmar;
i originally wanted to buy a Xaser VI LCS
(See someone does read the Stickies before posting)
But then while shopping for a HD4770 i came across this Site Which is stocking a CoolerMaster storm sniper AMD Special Edition Which cause i am a Crazy AMD fan, pretty much made me scream. Now i really want this case But my problem is that will all my parts fit even if it is a tight fit?
Proposed Specs; (feel free to recommend anything else)
Motherboard;
GA-MA790XT-UD4P
Processor;
AMD Phenom II X4 955
Memory (ram);
CORSAIR TW3X4G1333C9 8GB (4x XMS3 2GB) PC-10600
Storage;
SAMSUNG 1PK 1TB SATAII 3.5 32M
PSU;
CORSAIR 620W Corsair HX-620 ATX Modular Power Supply,
Okay here's were the problem begins;
Watercooling;
Thermaltake. Dual 5.25 Drive Bay liquid cooling system (CPU water block and 2x GPU water blocks)
Optical; (2x)
LG 22xDVD+-R, 12xDVD-RAM
AND
Graphics card:
Crossfire HD4770
+wIfi card/cold cathodes
So will this fit or will it just be too much for the case to handle?
Sponsored Links
Well the case "should" have everything fit in there, so it would be worth a try, if theres a return option.
Reply to tidefan94
I wouldn't put together a nice build like that and dump a couple of low end video cards in it unless I was gaming at 1024x768. All those fancy benchmarks aren't going to help those cards in the real world when it comes to premium games.
Reply to swifty_morgan
I have to agree with swifty_morgan, if you're going to go through the trouble of water cooling you might as well get a good pair of GPU's to Xfire. Try the 4870 1GB
but if you still want to go through with that, from the dimensions i looked at it should fit
Reply to thefox14
Thanks Tidefan94,
@ Swifty_morgan
Thanks for the sugestion but next time would you be kind enough to suggest another model or make? :D
@thefox14
Thank you, i thought of the 4870 512mb at one point, but i think that would great having 2 4870 1GB's in X-fire.
thanks, yeah it was just a sudden thought that it might not fit.
Reply to Nickos
Tom's Hardware > Forum > Homebuilt Systems > New System Build > Case Help.
There are 1189 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
