Hey everyone, I'm doing my first watercooling build and just wanted to ask a few questions to the more experienced people around. At first I thought a dual loop setup would be good, but then I read this and decided on the single loop that will cool:
- Intel Core i7-930 (Swiftech Apogee XT Rev 2)
- EVGA GTX580 (EK-FC580 GTX+ Nickel + Acetal)
- EVGA Classified Motherboard (EK-FB EVGA X58 CLASSIFIED Acetal+Nickel)
The build is on an Obsidian 800D case. I really want the setup to be silent, and read that I need a low fin density radiator that will work well with low RPM fans (I'm thinking 1000 RPM). My second priority is to make it as clean looking as possible. Basically, my questions are:
Radiator Questions
- Will a single XSPC RX360 mounted horizontally at the top of the case be enough to cool this single loop setup?
- If this isn't enough, would it be if I added another single 120mm radiator to the loop? I'm thinking at the bottom of the case; I know it can be modded to fit a dual 120mm radiator, but the less modding the better for me!
Pump Questions
- Can I set this up with a single MCP350 pump? Or should I use two MCP350 pumps in series?
Reservoir Questions
- Can the XSPC Dual 5.25" Bay - DDC Dual Pump / Dual Split Reservoirs be set up so that the two pumps are in series? I'm guessing one pump's output goes to the other's reservoir, is this good?
Thanks to anyone who responds, I really appreciate it! I don't wanna screw this up, so I'm trying to be as prepared as I can!
Radiator Questions
Pump Questions
Reservoir Questions
