With the Ram that you will be getting in that Combo, will not work with the Cooler Master V10, mainly due to height. I would suggest you get this CPU Cooler below.
I do believe McAfee ia now supporting Windows 7 OS. You can get it cheaper at McAfee own site andyou can also do the Trial version for 30 days. Link below.
http://home.mcafee.com/store/package.aspx?pkgid=273
Also get some USB Flash drives. One for Windows 7 OS, you will need a 16gb USB Memory Flash Drive should do. Like the Kingston DataTraveler 100 16GB Flash Drive and also get a couple 4gb or 8gb one's too.
Hope this helps you out some, Good Luck and have fun on your upcoming build.
Message edited by Yoosty on 06-21-2009 at 08:14:16 AM
ok i am getting the asus p6t and the extra fans and a fan controller and my budget is 2000 maybe a bit over but i wod like to keep the cooler master v10 i am overclocking to 3.2 4.0 ghz and the case is that the cooler master v10 fits
Re: Velociraptor
I'd just get one, save that money and then get an SSD in another year when price and quality improve. Your SATA2 connection can handle up to 300MB/second read or write. Any SATA SSD is compatible, if the SSD is faster than this it's throttled down to 300MB/second.
I'd rather have less noise over a speed boost to the Velociraptor. I find mine quite responsive. I've been reviewing SSD's for some time and finally found one of high enough quality but still too expensive and not enough capacity (OCZ Vortex).
Message edited by photonboy on 06-22-2009 at 10:32:44 AM
