Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Problem with O.C HD4850
Forum Graphic & Displays : Graphics Cards - Problem with O.C HD4850
I O.C my HD4850 from 625/993 to 700/1098 with ATi Catalyst Overdrive.. The test result was 'passed'... but when running FarCry2 at 1920x1080 BSOD appears(GPU stops responding)... which other O.C software would be better to attain stable clock..
Sponsored Links
I don't think it is the software. What are your temps before it "stops responding"? What cooler do you have on the card?
Reply to ragsters
ok, to let you on a little fact, the ati overdrive thing that "tests" the GPUs is totally BS
it said i could overclock my 3870s with a core clock of 890mhz and 1375mhz mem clock!!!!
I personally just know what my cards can handle from the pains of crash reports and GPU not responding reports. im sure there are some good softwares out there that let you test out your OCed settings but i dont use any.
Reply to rambo117
My card never/ever goes above 60ºC... Usually it works at 50ºC-54ºC
Its from MSI, looks like this:
http://www.geeks3d.com/public/jegx [...] 01-big.jpg
Reply to meodowla
I tried FarCry2 Benchmark tool, PC MArk Vantage etc... ended up with BSOD(After O.C)..
Reply to meodowla
3D Mark06 works well. It scored 12720
Reply to meodowla
he only sure fire way to make sure it is stable is to play your favourite games.. If it crashes then back off the OC a bit and try again. There is so software that could find every instability, though any benchmark utility will give you some idea of the stability.
------------------------------ CPU: Q9550 at 3.6ghz (FSB 425mhz) | MB: P5E3 Premium | Ram: 4*2Gb Corsair DDR3 @1417mhz | GPU: 2 HD4890 1Gb (925core/1025mem) CF | PSU: OCZ ELiteXtreme 800W | Sound: Creative Titanium Fatal1ty Pro | 2*120gb OCZ Vertex SSD Raid0 and 2 500gb Raid0 HDDS
Reply to daedalus685
Use ATITool to scan for stability. From my experience with a Sapphire HD 4850, I got it up to 690/1050 without errors. Going higher, while being stable, would require volt mods.
Reply to orangegator
A tried ATI Tool... the artifact showed Delta Pixels... so it mean, not stable.. cool..
Reply to meodowla
There are 1383 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
