GTW - 158W up to 320W
AMD 125 W
Mem 8/20 - 65W [1-98-682-709 (john)]
DVD/CD 20W - 30W
Hard Drive 15W - 30W
Average PCI Card 5W - 10W
Motherboard (w/o CPU or RAM) 50W - 150W
Case/CPU Fans 3W (ea.)
750W - 800W with everything maxed out.
Hello Everyone,
I'm building the following system and I'm trying to figure how much power I need to run it:
Motherboard: GIGABYTE GA-MA770T-UD3P
+Graphics Card: eVGA nVidia 8800 GTX 712mb /w the cooler/sync: Arctic Accelero X8800
+ CPU: AMD Phenom II 940 BE (3.0GHz factory but will overclock to 3.7GHz when gaming) /w cooler/sync: Arctic Freezer 64 Pro
+ Memory: 4GB DDR3 Kingston 1333MHz (2 modules)
+1 Computer Fan
+ 1 SATA 1TB drive
+ 1 or 2 ATA drives
+ 1 DVD/CD Burner
+ 1 HongKong-Bought 5.25' internal card read, USB-Firewire Bay
+ 1 PCI Wifi card
+ 1 PCI modem card
I would like to spend the minimum amount on power supplies without compromising this system I've taken so much pain to research, purchase the parts and assemble. I'm currently looking at the OCZ 750W GameXStream on ebay. The 750W is relatively cheap, the 850W jump to double or 50% over the 750W cost. If I can get away with the 750W or even the 600, I would much prefer that.
As I understand it, the 750W rating is PEAK and that I shouldn't be running the computer that often anywhere near that (OCZ techie told me to run it at 80% which would leave me a continuous operating level of 600W with a 150W grace zone).
I'm less worried about normal operation and more about the 4 or 5 hours of gaming that I'd do with the graphics card not getting enough juice, the game crashing, turning sluggish or the box shutting down b/c it's overloaded.
Could anyone give me some feedback?
As to how much I need?
Thanks! Fadi
A decent 500W PSU will be enough. Antec, Corsair, PC Power & Cooling, Seasonic, and Enermax are among the better brands. Choose one that has full range active PFC and is 80+ certified.
Your system is not a power hog. The Corsair VX450 mentioned by ekoostik can power your system. There is more than enough current (amps) on the 12 volt rail to easily handle an 8800 GTX video card.
While 750w is serious overkill, I certainly would NOT recommend a 450w. Why? Because sooner or later you going to upgrade that video card, and maybe cpu and then your just gonna have to buy a new psu again. Get a good quality 600-650w.
zipzoomflyhigh - about that upgrade - Have you read the technical reviews for the ATI Radeon HD 5870? They are pretty efficient cards. Anantech did an excellent review and they measured total power consumption at the wall outlet (mains) for an Intel Core i7 920 2.66 Ghz system overclocked to 3.33 Ghz with a single 5870 while playing World of Warcarft. They also did a second test with two 5870's operating in Crossfire mode. Total power draw for one video card was 295 watts. Total power draw with two 5870's was 430 watts.
The results for one video card were consistent with the results published in a Tom's Hardware article last January that also showed power consumption during gaming. The typical gamer uses a little less than 300 watts during a gaming session. Here we have an overclocked Core i7 920 and a brand new high end video card doing the same. The 5870 uses about 10% less power than current generation cards.
We also have more energy efficient cpu's and gpu's coming based on new 32nm technology that will require even less power. Intel just did a show and tell presentation of one of those new cpu's. The future will see us using less energy rather than more.
The 5870 uses 10% less power than current generation cards? Umm...no.
The 5870 uses 188w and the 4870 uses 160w, thats more not less. And newer cards will have more and faster ram, which also requires more power.
While 32nm processors may use less power per core, they will have more cores, therefore using more power. Newer processors also tend to have more cache, which also uses power. Considering i7 uses more power than C2Q's and X4's, I'd have to argue that cpu power requirements are going up, not down.
I would not recommend a 450w power supply with a video card that uses 188w and a cpu that uses 130w (not overclocked). Thats 318w at stock clocks. Overclock the video card and the processor and your easily at 400w. That leaves almost no room for soundcards, memory, motherboard, fans, hdd's, optical drives and other peripherals.
Message edited by zipzoomflyhigh on 09-24-2009 at 10:36:35 PM
zip - The Intel Core i7 920 was definitely overclocked to 3.33 Ghz. The total draw at the wall outlet for the entire system with one 5870 was only 295 watts during a gaming session. The psu in the overclocked system drew less power than the 318 watts at stock settings which you suggested. How can a overclocked system during a gaming session use less power than the rated power? In fact, how can an overlocked system at idle use only 27 watts instead of the rated 318 watts? Pretty simple - The numbers you quoted do not reflect actual usage.
I know an easy way to settle this, other than reading those reviews. I just happen to own a Corsair 450VX. Now if someone would send me an i7 920, mother board, and 5870 I would be more than happy to report back my findings.
Thats impossible. A 130w processor overclocked with a 188w 5870 could not draw only 295w. The number I quoted came from THG's own testing.
