Ok so I have never actually built a computer, but I've learned how to build one. I wanted to see if these parts would work all together and if its good for playing Left 4 dead on 1900 by 1200 with everything MAXED. Here are the parts.
Yeah those would all work together fine. I'm not sure about Apevia psu's, I would go with a Corsairs one but you probably wouldnt have any trouble with it. Also, you should really buy from newegg.com, they're generally cheaper on alot of things. If you tell me your whole budget I could suggest another build for you.
This is just a suggestion based off how much you were going to pay for those other parts. Dual 4890's destroy any game you throw at it for quite some time. It would destroy L4D at whatever res u want.
^Nothing wrong with the EVGA board listed, but with the current market, the ATI prices are dropping fast, and you should be able to put in a second 4850 with the UD3R.
Like I said above, you probably don't need a SLI/CrossFire set up for L4D at 1900*1200. Eitherway, game with a single GPU first and then if needed, just add in a 2nd GPU in SLI/CrossFire, which ever one floats your boar.
LMFAO!! Boar? also how long do you think this build would last?
The build that I put together would have much better gaming performance than the other suggestions. The Q9650 is a little better than the X4 955 but the 4890s are far superior than the 4850's or 9800gt's. If you wanted to save some money though u could go with a single 4890. Whichever u prefer.
Alright I've made a new build here are the parts also they are all from new egg so thats why i left item number so u can look for your self and see if there compatible this is my first list build woth an AMD CPU o ya also ignore the video card not being there im gonna get that later just trying to keep a budget here
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail
Model #:HDZ955FBGIBOX
Item #:N82E16819103674
Yeah everything looks great. Do you really need vista ultimate? Vista home premium would work just fine and its a good amount cheaper. Just sayin'. Other than that, nice build.
Thanks huys but just wanna clarify, everything works together right. also how long would the build last like say i didnt get these parts until december would it still be a decnt gaming system like for max settings regular FPS games like L4D COD4 n such u thnk itd still b good for L4D2 and CODMW2?
If waiting till December you could probably go with an i5 which comes close to an i7 in performance.
hmmm if i bought the lexa case u thnk itd still be good 4 december nonono ill wait price 4 case will prolly drop hmmmm hey guys i got one last question if i have the desktop that uses DDR2 800megahertz of one gig could i use 2 sticks of ram of 2 gigs in each and 1333 MHTz also i hav 32 bit so i kno itll only read 3 gigs
