It's been my understanding since I bought this processor that it runs pretty hot. That said: it started getting really hot. Like 70c idle 90-100c load. I decided that I would opt for water cooling solutions or a Corsair h60 if reseating with some Arctic Silver 5 had no effect.
This is all with a Scythe Mugen 2, in what I think is a pretty well ventilated case. Picture of the case below. Arrows point in direction of the fans. There's one additional intake by the HD bay, labeled with an arrow.
http://imageshack.us/f/834/imag0203j.jpg/
The following is a screen-cap of a sensor test run by Prime95 through Real Temp 3.40.
http://imageshack.us/photo/my-images/263/sensortest.jpg/
Cores 2 and 4 have read Thermal Status: LOG since bootup.
The AS5 was applied in a thin line down the CPU, as recommended by the AS5 handbook in regards to i7 processors. This test was done prior to putting on both of the side panels on the case. Also there is that whole break in period I suppose.
The idle temp you see in the screen-cap seems to be pretty steady right now, although I suppose there is that whole break-in period so maybe it will drop a few.
Still getting pretty damn hot under load, even though temps seem better idle. What do you guys think? Still too hot?
Thanks for looking.
edit: Reboot and Thermal Status across all cores reads: OK
Thanks for looking.
