Start Menu Context Menu Problems
Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
I'm having an issue with the "Open"/"Open All
Users", "Explore"/"Explore All Users" context menu
options (right click menu) for shortcut folders (such
as "Accessories") under the "All Programs" list on
the "Start Menu" in Windows XP Home Edition.
Performing this action is supposed to open a My
Computer/Windows Explorer window browsing the selected
start menu folder. Normally, double clicking a start menu
folder will also "Open" a My Computer window browsing the
selected start menu folder. I use these features often
when editing and customizing start menu shortcuts and
folders. Currently, these actions don't function and
simply close the context menu/Start Menu without bringing
up a My Computer/Windows Explorer window.
If I right click the "Start" button directly and select
the corresponding options ("Open"/"Open All
Users", "Explore"/"Explore All Users") a My
Computer/Windows Explorer window is brought up as
expected browsing "C:\Documents and Settings\Owner\Start
Menu" and "C:\Documents and Settings\All Users\Start
Menu" respectively.
Is this a registry/virus issue? How do I fix this? Do I
need to reinstall the OS to resolve this annoying
problem? I've performed a full virus system scan with
virus definitions to date, and have had the Windows
network connection firewall enabled prior to the initial
internet connection. The computer is 1 day old!!!
6 answers Last reply
More about start menu context menu problems
  1. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    It's caused be third part programs. AVG anti virus is one.
    Type Regedit in Start Run
    Goto
    HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers
    HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers
    HKEY_CLASSES_ROOT\Directory\shellex\ContextMenuHandlers
    HKEY_CLASSES_ROOT\Drive\shellex\ContextMenuHandlers
    HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers
    Export all five keys (on the File Menu) (First two keys apply to files, 1st, 3rd to 5th apply to folders/drives). Delete all two/five. What happens.
    'Not happy John! Defending our democracy',
    http://www.smh.com.au/articles/2004/06/29/1088392635123.html
    "Flux" <anonymous@discussions.microsoft.com> wrote in message news:24a9a01c45fda$fa2c4110$a301280a@phx.gbl...
    > Menu" respectively.
  2. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    "David Candy" <david@mvps.org>,
    Thankyou very much for the response!! I apologize for the
    delay. I've been busy unfortunately and haven't had time
    to address this issue or get back to the forum :( . I
    have not yet performed the actions you suggested.
    I'm assuming the purpose of exporting the five mentioned
    keys and values is for backup purposes while editing in
    the event I may need to import them back. Can you kindly
    clarify what you mean in the above statement. My
    understanding is that I am ONLY to delete the following
    keys:
    P.S. Very interesting that you happened to mention the
    anti virus as a potential cause of this issue. The system
    IS running AVG... I wonder how common this issue occurs
    under AVG users...
    >-----Original Message-----
    one.
    >Goto
    uHandlers
    menu
    the
    bringing
    select
    >> Menu" respectively.
    I
    initial
  3. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    I went ahead and deleted keys 2 and 5 (previous message
    below) which contained the following sub keys:
    ____________________________________
    [HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers]
    [\AVG Shell Extension]
    @="{1E2CDF40-419B-11D2-A5A1-002018648BA7}"
    [\Offline Files]
    @="{750fdf0e-2a26-11d1-a3ea-080036587f03}"
    [\Open With]
    @="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
    [\Open With EncryptionMenu]
    @="{A470F8CF-A1E8-4f65-8335-227475AA5C46}"
    [\{a2a9545d-a0c2-42b4-9708-a0b2badd77c8}]
    @="Start Menu Pin"
    [HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers]
    After removing these two parent keys, functionality to
    the "Open"/"Open All Users", "Explore"/"Explore All
    Users" context menu options for shortcut folders under
    the "All Programs" list on the "Start Menu" was restored!
    I will be importing the original keys and, through trial
    and error, try and determine which subkey(s) is/are
    responsible for this issue and post the results here.
    Thanks again!!
    one.
    >Goto
    uHandlers
    menu
    the
    bringing
    select
    >> Menu" respectively.
    I
    initial
  4. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    I've located the registry error created by AVG in the
    following parent key:
    [HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers\AVG
    Shell Extension]
    Removing the "AVG Shell Extension" key will remove the
    issue with "Open"/"Open All Users", "Explore"/"Explore
    All Users" context menu options but will remove the "Scan
    with AVG" option in context menus when right clicking on
    folders.
    one.
    >Goto
    uHandlers
    tml
    menu
    the
    bringing
    select
    >> Menu" respectively.
    I
    initial
  5. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    yes. Though on SP1 it seems to work ok.
    "Flux" <anonymous@discussions.microsoft.com> wrote in message news:262f901c46221$e2a2f630$a401280a@phx.gbl...
    > Shell Extension]
    > folders.
    > one.
    > >Goto
    > uHandlers
    > tml
    > menu
    > the
    > bringing
    > select
    > >> Menu" respectively.
    > I
    > initial
  6. Archived from groups: microsoft.public.windowsxp.configuration_manage (More info?)
    I've installed the latest AVG (v6.0.716) on three
    separate systems running Windows XP Home Edition (v
    5.1.2600 Service Pack 1 Build 2600) and all perform the
    same causing the context menu issue post installation.
    Perhaps your test involved AVG and XP Professional ?? ...
    I'm not familiar with AVG and XP Pro at this point,
    although I would expect it to function the same...
    tml
    >> Shell Extension]
    the "Scan
    on
    >> folders.
    >> one.
    >> >Goto
    >> uHandlers
    keys
    folders/drives).
    >> tml
    (such
    selected
    start
    >> menu
    browsing
    >> the
    often
    and
    and
    >> bringing
    >> select
    Users\Start
    >> >> Menu" respectively.
    Do
    >> I
    with
    >> initial
Configuration Windows Explorer Start Menu Computers Windows XP
