New System Advice
Hi all - I am getting a new system and want to make sure these pieces will be ok / compatible. I will assemble it myself but I am a bit of a rookie.
Please advise if you think I should change anything.
MBo - Gigabyte P55M-UD2 mATX LGA1156 P55 DDR3
Mem - G.SKILL F3-12800CL9D-4GBNQ PC3-12800 4GB
CPU - Intel Core i7 860 Quad Core Processor
HDD - Western Digital Caviar Black (WD1001FALS) 1000GB (1TB)
Vid - Older ATI vid card X1900 xtx
Thanks.
More about : system advice
Honestly, the video card is extremely lacking. If it were me, I'd save up some extra cash, or spend less on one of the above components and get a respectable card.
The rest looks OK, but don't see a PSU listed - please don't tell me you are reusing a generic, average PSU.
OCZ is an OK brand as well. That's good to hear. If you are going to get a new graphics card in a month, is there a reason you are pulling the trigger on the rest now?
I may be getting an ATI 4850 from a friend - if so I won't need a new card - I will use my old one while I am waiting to see. :D
I was mainly torn between the i7 860 and the i7 920 - I think I will go with the 860 as it appears a little faster and I won't upgrade the CPU in future - I will wait for the next generation entirely.
The other thing I was wondering was whether that memory seems ok - I don't know anything about memory - I did check the vendor list so I should be ok there.
Cheers.
Ask the community
