Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Help with a homebuilt system
Forum Homebuilt Systems : General Homebuilt - Help with a homebuilt system
Hello everybody!
I'm having an issue with one of my homebuilt systems. This computer has the following configuration:
Processor: Intel Core 2 Quad Q8200
Memory: Kingston DDR2 2x1GB PC6400
Graphic Card: BFG 9600GT
Motherboard: Asrock P43Twins1600
OS: Windows XP Professional SP 3
What my problem is, is that this computer is EXTREMELY slow. It takes up to 3 minutes to boot up the system and use it properly. I have no idea why this happens. I've updated the bios to the latest one (2.0) and still no difference.
I really look for an answer to my problem because it's been going like this for 5 months.
Thank you for your help!
Message edited by bobitza91 on 06-22-2009 at 10:35:51 AM
Sponsored Links
I forgot to mention:
OS: Windows XP Professional Service Pack 3
Reply to bobitza91
have you tried running any tests on your ram and hard drive to see if there working fine?
Reply to captaincharisma
What hard drive are you running at that is often the limiting factor in boot times
Reply to hunter315
Have you installed the motherboard drivers from the disk that came with your board?
------------------------------ ßolweval
Reply to bolweval
I have found the problem. I guess the problem was the partition on which the Windows was installed on. I reinstalled on another partition and it seems that everything runs smoothly. Thank you all anyway!
Reply to bobitza91
There are 1038 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
