I got a whole new system the other day, put it together, and installed all updates, drivers, and antivirus. Downloaded all the system monitors i could find (speedTemp, SpeedFan, Aida64, and CPUID ZPU-z) and also downloaded Prime95, Super Pi, and 3D Mark Vantage.
My system:
I5-2500k @ 4.4Ghz
Corsair CPU Cooler A50
Gigabyte GA-Z68A-D3H-B3
PNY optima 4gb 1333mhz x 2
XFX Radeon HD 6870
Samsung Spinpoint 1tb
Antec 750w PSU
and 4 Antec case fans variable speed (all set on high)
I slowly moved my turbo boost to 44 x from 34 x by (2 at a time). I ran Prime 95 at boot along with Realtemp, Speed Fan, and CPUID CPu-z for 3 hours after every change.
I got to 4.4Ghz with Average Temps at practically 0% use: 25c, 29c, 28c, 30c
High Temps=30c on all
Low Temps=23c, 24c,27c,28c
Once i run Prime95 Average temps rise to: 56-59c on every core
High temp recorded after 3 hours= 59c, 67c, 59c, 69c
Low temp recorded after 3 hours= 46c,47c,46c,49c
I figured this was pretty stable after about three hours (i know your suppose to run Prime for 24 hours to be sure of stability but i planned on going a little higher. I decided to go up by jump my turbo up by 1 x (4.5Ghz) and i loaded windows, loaded all my monitors, and then opened Prime95 and got BSOD immediately.
Have a reached my limit?
Are these temps decent i know i dont have the acclaimed 212 cpu cooler?
All my voltage settings are pretty much (auto). My QPI/Vtt voltage is at 1.050v, Dynamic Vcore= Auto, Dram Voltage=1.50, BCKL=100.0MHz.
I was wondering... I have 8 gb of memory installed, My board shows that memory is installed in slot 1 and 3 yet the sticks are right next to each other. Should i move my slot 3 stick into slot 2? Will this make a difference?
Also i have 4x2gb Hynix ram at same speed as my 2x4gb sticks. Should i use the 4 sticks or the 2 sticks? Lastly Can i mix the ram and use 2x4gb and 2x2gb as the ram is the same speed?
My system:
I5-2500k @ 4.4Ghz
XFX Radeon HD 6870
Antec 750w PSU
