Will this powersupply work for the geforce gtx 285 card?
  • Nvidia
  • Gtx
  • Powersupply
  • Geforce
  • Graphics
  • Product
July 14, 2009 5:42:44 AM
The card has a recomended power requirement of 550W and 40A on the 12v rails. will this 600W PSU work? http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Output +3.3V@24A, +5V@15A, +12V1@30A, +12V2@22A, -12V@0.3A, +5VSB@2.5A
can the card use multiple 12v rails? or will the 2 6 pin supplimentary cords help provide the amps required?
More about : powersupply work geforce gtx 285 card
July 14, 2009 7:46:48 AM
I second that. The one thing you never want to skimp on is the PSU.
a b Î Nvidia
July 14, 2009 12:04:04 PM
Yes, but get something better, cheap powersupplies can kill a system if they fail and often struggle to reach their declared output, leading to an unstable system.
If you do not want to use the unit linked by IH8U look for 550-650W with twin 6+2
pin PCI-E cables from: Corsair, Pc Power and Cooling, Ocz, Antec or Seasonic.
