tell me if this build will work
PLEXTOR Black 22X DVD+R 8X DVD+RW 8X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner
http://www.newegg.com/Product/Prod [...] 6827249043
COOLER MASTER Storm Sniper SGC-6000-KKN1-GP Black ABS Bezel, SECC Body ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811119194
Scythe KM02-BK 5.25" Bay Fan Controller
http://www.newegg.com/Product/Prod [...] 6811998055
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Prod [...] 6822136322
ASUS VH226H Black 21.5" 2ms(GTG) HDMI Widescreen 16:9 Full HD 1080P LCD Monitor 300 cd/m2 1000:1 (ASCR 12000 : 1) Built in Speakers
http://www.newegg.com/Product/Prod [...] 6824236051
CORSAIR CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Prod [...] 6817139007
Microsoft Digital Media Pro BX1-00005 2-Tone 105 Normal Keys 22 Function Keys + 1 Zoom Slider Function Keys USB or PS/2 Wired Standard Keyboard
http://www.newegg.com/Product/Prod [...] 6823109137
Microsoft N71-00007S Black 3 Buttons 1 x Wheel USB Wired Optical Wheel Mouse
http://www.newegg.com/Product/Prod [...] 6826105026
CORSAIR DOMINATOR 3GB (3 x 1GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X3G1600C8D
http://www.newegg.com/Product/Prod [...] 6820145225 x2
ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813131359
Thermaltake A2018 120mm Blue LED Case Fan
http://www.newegg.com/Product/Prod [...] 6811999122 x4
COOLER MASTER V10 Hybrid TEC RR-B2P-UV10-GP 120mm CPU Cooler
http://www.newegg.com/Product/Prod [...] 6835103056
Arctic Silver 5 Thermal Compound
http://www.newegg.com/Product/Prod [...] 6835100007
Nippon Labs 6 ft. HDMI TO HDMI A/V Gold Plated Cable Model HDMI1.3-6
http://www.newegg.com/Product/Prod [...] 6812816002
SAPPHIRE 100269SR Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.com/Product/Prod [...] 6814102830
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor
http://www.newegg.com/Product/Prod [...] 6819115202
price $2,016.77
overclock 3.2 to 4.0 ghz somewhere around there
will the memory and the cpu cooler work
will this motherboard overclock that high and will the fans cool good for that kind of overclock and no watercooling
will 2 of the GPUs crossfire and play any game in 1080p and maybe when the ati radeon 4890 x2 r here i can do quad gpu or 3 way gpu crossfire
i will add raptors and my goal is 4 raptors raid 0 and 1 2tb wd drive
and i will add blu-ray later
Sponsored Links
At that price point I think the UD4P is the better buy, but it's not a huge deal:
http://www.newegg.com/Product/Prod [...] 6813128374
Better timings and you get 6GB instead of 3 for about the same price:
http://www.newegg.com/Product/Prod [...] 6820227381
Two 4890s will be all you need. The 1000HX is overkill for two, but it's a nice PSU. The 850HX is a bit better quality probably:
http://www.newegg.com/Product/Prod [...] &Tpk=850HX
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
V10 is a waste of money. Go for the Noctua NH-U12P SE1366.
+1 on the 850HX
The VRap is also a waste of money, go for the WD6401AALS, it will be almost as fast, twice as large, and a third the price.
------------------------------ Asus P6T & i7 920 @ 3.6ghz
GTX 260 Core 216
6gb 1443MHZ 7-7-7-18 1T OCZ Platinum
CM RC-690, CM V8 HSF
Reply to xthekidx
i will go for the ram thanks but the mobo i will go with asus and the power supply yes the only thang i see between the 2 is 1 more cpu 8 pin power
Reply to psp_man13
the case is made to support the v10 so it will work less and do more and i like the tec
Reply to psp_man13
Yeah the TEC looks to be about 5C better under overclocked load, and that's decent. Cheaper than water. As long as it works :) I hope it has a good warranty.
Reply to Proximon
if i get 2 6gb kit 3x1gb kit will that work better
Reply to psp_man13
lol i mean 2 3gb kits
Reply to psp_man13
3x2GB uses less power and tends to cost a bit less, it also gives you the option of upgrading to 12GB in the future without needing to throw out 3GB of ram
Reply to hunter315
i cant put ram in this but 1 time
i am getting the cooler master v10
Reply to psp_man13
Where? I haven't seen anything to that effect. From what I have seen, the V10 is barely better than the $40-$50 coolers and weighs twice as much, putting much more strain on the MB and increasing the chance of damage if you move the computer around.
GTX 260 Core 216
Reply to xthekidx
the computer will stay in 1 spot for most of the time if i move it i will turn it off and remove it but i want to know if i remove it will i need to replace the thermal compound and the case i have i can remove it and dont have to take the mother board out
Reply to psp_man13
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner
http://www.newegg.com/Product/Prod [...] 6827151171
Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Prod [...] 6822136296
Saitek PZ30AU Black 104 Normal Keys 4 Function Keys USB Standard Eclipse Keyboard
http://www.newegg.com/Product/Prod [...] 6823175103
Logitech MX518 8 Buttons 1 x Wheel USB Wired Optical 1800 dpi Gaming-Grade Mouse
http://www.newegg.com/Product/Prod [...] 6826104178
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D
http://www.newegg.com/Product/Prod [...] 6820145224
Intel BOXDX58SO LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Prod [...] 6813121361
ZALMAN CNPS10X Extreme 120mm 2 Ball CPU Cooler
http://www.newegg.com/Product/Prod [...] 6835118051
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811129058
Antec EA750 750W ATX12V version 2.3 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC "compatible with Core i7" Power Supply
http://www.newegg.com/Product/Prod [...] 6817371026
Reply to psp_man13
how about that will that work i am just 15 trying to make my first build
Reply to psp_man13
V10 review:
http://www.overclockersclub.com/reviews/cm_v10/4.htm
http://www.xtremesystems.org/forum [...] p?t=216567
What I'm seeing here is that the cooler only really shines at higher temps, holding those down better than air coolers.
If you want to save some money, get this proven air cooler:
http://www.newegg.com/Product/Prod [...] 6835185093
And as I said before, the Corsair Dominator RAM is overpriced. The OCZ kit I linked will work fine.
Don't use Intel motherboards. They are quite gimpy.
Reply to Proximon
what do you mean gimpy
Reply to psp_man13
i am making an i7 build for 2000 i am 15 what wod you suggest
Reply to psp_man13
I would go with your first build over your second build & take into account everyone's comments. We are trying to help improve upon your build.
Example: WD 640 instead of the WD 300 VRaptor. The 640 cost roughly $75 vs $225 for the VRaptor for close to the same performance. The group is trying to get you the best / better performance for equal or less money.
Example: 850TX vs 1000HX. You would be better suited with the 850TX, instead of spending more on a PSU wattage you don't require.
Give these some thoughts... :). You are way ahead of where I was at 15 but of course my super computer was a Commodor64 at that age :)
------------------------------ Recommended Builds by Usage
Step-by-Step Guide to Building a PC
Reply to tecmo34
Intel motherboards don't overclock well, if at all. They also have had quality issues in recent years, perhaps because they don't sell many.
Gigabyte and Asus are the two brands you want to stay with for motherboards.
Reply to Proximon
how about that it looks better
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Prod [...] 6822136320
CORSAIR CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 Modular Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] 6817139011
OCZ XMP Ready Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3X1600LV6GK
http://www.newegg.com/Product/Prod [...] 6820227388
Antec 761345-75024-0 120mm Blue LED Case Fan
http://www.newegg.com/Product/Prod [...] 6835209011
Reply to psp_man13
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Prod [...] 6817139006
Reply to psp_man13
the 850hx is super solid if you want a modular PSU, however its also significantly more expensive and the 750tx will be more than strong enough even if you decide to crossfire in the future
Reply to hunter315
+1 hunter315...
Your new build is very solid... Well done!
Reply to tecmo34
crossfire is what i wanted later and i want to know when i install windows do i need 2 dvd drives for the raid controller driver
Reply to psp_man13
do i need a floppy drive for the raid driver
Reply to psp_man13
*Edit
* note to self...read the entire thread before posting.
Message edited by Why_Me on 06-23-2009 at 05:24:55 AM
------------------------------ "God invented Google so you would stop asking stupid questions."
Reply to Why_Me
What OS will you be using? Try windows-7. You will have to buy and clean reinstall the official version by next summer. Or, look for an academic price on vista home premium-64 bit.
I think you can do better on the cpu cooler. Pick one of the top units in this review:
http://benchmarkreviews.com/index. [...] itstart=16
Corsair or PC P&C 750w unit should be sufficient. If you want more, look at PC P&C silencer910. It is a bit stronger and cheaper with silver efficiency rating:
http://www.newegg.com/Product/Prod [...] 6817703022
Reply to geofelt
i need a big psu for add ons later and i am gone dual boot a old copy of xp 64 and win 7 i hate vista and i changed my mind if i overclock it will be 3.0 ghz or maybe 3.2
and from what i hear it will not get 2 hot
Reply to psp_man13
what about vista basic 64 will it suppoert 6gigs maybe 12 who knows 24
Reply to psp_man13
if you will only go to 3.2ghz or so then the V10 is a terrible waste of your money. Go for the Xigmatek S1283V DK or Scythe Mugen 2, they will allow an OC up to 3.6-3.8ghz pretty comfortably, and cost 1/4th the price of the V10.
GTX 260 Core 216
Reply to xthekidx
Vista Basic 64bit only allows 8gb of ram.
GTX 260 Core 216
Reply to xthekidx
i am gona use the zalman cnps10x read bfor you write
so vista premium or win 7
i use win 7 now on my dell i guess i can use it but will the raid drivers work
i will raid-0 2x500gb drives
Reply to psp_man13
Consider what you are saying before you are rude to the people who are helping you and trying to get you the most for your money.
That Zalman cooler is new and not heavily reviewed. While initial results are promising, the only full review on it was french:
http://vr-zone.com/forums/442000/z [...] iewed.html
While it seems to do well, its more expensive than other coolers that perform similarly, like the two that I mentioned above. Its your money, and if you feel like wasting it then that is your perrogative. But there is no reason to buy an expensive cooler like that if you are only going to OC to 3.2ghz. The coolers that I listed cost half as much and will perform very close, only at high overclocks 3.8ghz+ would you begin to see a difference in temperatures.
I will let others point out the other flaws in your build, I am done with this thread. I do not help people who act like they are doing me favors by providing threads for me to offer my advice on.
Message edited by xthekidx on 06-23-2009 at 08:54:21 AM
GTX 260 Core 216
Reply to xthekidx
sorry it wos a joke but if it dont cool good i will send it back
what cooler do you use
Reply to psp_man13
Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help first build
There are 1231 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
