Tom's Hardware > Forum > CPU & Components > Other Components > [Solved] How do you replace lost power adapters?
Forum CPU & Components : Other Components - [Solved] How do you replace lost power adapters?
Best answer from sminlal.
I have a D-Link router wbr-1310 and lost the power adapter 5v 2.5a. Generally how do you find one that will fit in the power receptor and will be the right output? Does it matter if you go over the power amount at like 6v 3a?
Radio shack sells adjustable power transformers with interchangeable plugs which will fit a pretty large range of equipment.
You want to find an adapter that has the SAME VOLTAGE and a current (amp) rating that's AT LEAST as high as required by the equipment you're powering.
Sponsored Links
Try your local electronics store or contact the maker.
Reply to amdfangirl
Best answer
Reply to sminlal
You know your stuff
Message edited by norrisb on 09-27-2009 at 12:09:08 AM
Reply to norrisb
most also allow the tip polarity to be set, as that can vary as well.
Reply to tmike
There are 1203 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
