Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Which Thermaltake Power supplies should i go with?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Which Thermaltake Power supplies should i go with?
http://www.newegg.com/Product/Prod [...] 6817153036 Thermaltake toughpower W0117RU 750W
http://www.newegg.com/Product/Prod [...] 6817153038 Thermaltake W0116RU 750W Complies
CPU - Q9550
Memory - 4gb 1066
Video card - Diamond 4890 series
Harddrive - 750GB western digital
Heatsink - V8 Coolermaster
Motherboard - GIGABYTE GA-EP45-UD3P
4-5 120MM fans
Sponsored Links
the first one http://www.pcper.com/article.php?aid=266
quoted conclusion.......
If you are in the market for a power supply in the 600~750 watt range, one of the new Thermaltake Toughpower units deserve a close look. The 750W model exhibited very good voltage regulation and stability and was quiet, especially while operating under moderate loads. The overall efficiency is very good and Active PFC, sleeved cables, and a 3-year warranty are added pluses. The Toughpower 750W is notably the best power supply I have ever tested from Themaltake.
Message edited by sirkillalot on 09-26-2009 at 10:37:28 AM
------------------------------ AMD P2955X4 ATI 5870 DX11 [:boudy:2]
24" dell 1900x1200 2x74 wraptor hd's1 X-FI pro gamer sounds
2G ram log.Z5500 speakers 650w toughpower G15kb dvd....ITS A MEAN GREEN GAMING MACHINE
Reply to sirkillalot
One is a modular unit and one is a hardwired unit. The choice is a matter of personal preference.
Here is a link to a technical review of the modular version:
http://www.jonnyguru.com/modules.p [...] ory&reid=7
Message edited by JohnnyLucky on 09-26-2009 at 10:52:47 AM
Reply to JohnnyLucky
- 0 +
I have the toughpower 750W and its been 100% reliable since I got it. It is quiet and easily powerful to drive my OC'd i7 system. Its modular as well, which makes for a neat interior. I'd recommended it.
Reply to emyyhh
corsair or enermax
Reply to jimishtar
yep i find them good i have the 650w :sol:
There are 1172 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
