Zalman VF1000 fan connection issue
July 15, 2009 1:13:14 AM
So I got zalman vf1000 cooler for my nvidia 8800gt, everything was fine till i got to the part where I am supposed to connect the fan to the motherboard. The fan controller and the fan 3 pin connector should be connected to motherboard but the problem is that my motherboards doesn't seem to have 3 pin connector (either that or i am blind). I never knew that the fan connected to the motherboard and not the GPU its self. I did some research on the zalman vga cooler before I got it and i never came across someone with this issue.
I got dell xps 430 (idk if that's important) and i can post a picture of inside so you guys can see it. If my motherboard really doesn't have 3 pin connector than what are my options?
I hope someone here knows what I should do:(
I'll post pics too ...
More about : zalman vf1000 fan connection issue
July 15, 2009 1:33:59 AM
Here are the pics.
July 16, 2009 12:46:15 AM
Ok, so i went out and got that cable and it works...:)
Thanks a lot ragsters, I appreciate it.
July 16, 2009 2:22:54 AM
No problem Bosnique.
