First time LC setup for HAF 932 i7 build-help with parts
I just recently purchased a i7 build and would like some advice on parts for the LC. It is my first time but I would like a CPU and GPU LC with the option to upgrade to NB etc.
Specifications:
HAF 932
i7 920
EVGA x58 3xSLI (Vanilla)
2x EVGA GTX275
6GB Mushkin Ram (3x2@1600MHz)
300GB Velociraptor
500GB Western Digital
1000W Corsair HX PSU
I don't really have a budget but please be reasonable. I am NOT willing to sacrifice performance for price. Also I do not want to mod anything on this case but am willing to have things mounted on the exterior of the case. Any help is appreciated.
Thanks,
Mikey12
P.S. I HAVE read the guide to install just need some help picking parts as the sites have so many to chose from.
1 answer Last reply
More about first time setup build help parts
  1. You want to water cool the CPU and also both GPUs?
    You say you don't have a budget, but do you have some vague idea what you think it will cost?
    I'll guess around $500 if you are conservative.
    You'll need
    -A pump
    -A CPU block
    -Hose
    -Clamps
    -2 GPU blocks
    -A reservoir
    -A radiator
    -Fans
    You can do a lot better posting this question here:
    http://www.xtremesystems.org/forums/forumdisplay.php?f=70
    Read the stickies first.
Homebuilt Intel i7 Build Systems Product
