Hi,
I just bought a Dell 545 Inspiron (core 2 Quad with 8 gb memory and 4mb cache) -- it comes with integrated graphics, which seems to have OK graphics performance for what I do.
But, I can't use my 2nd display on it, and I am really addicted to two displays.
So, can anyone recommend a display card that supports two monitors. I would like low power consumption.
I'm not a gamer -- I do some CAD work and some photo editing/website building -- but nothing really demanding.
I like the idea that the new computer runs on half as much power (50 watts) as my old one, and I definitely don't want a power hog graphics card.
I was going to say any of those would do the trick, but ct1615 beat me to it and his suggestions are great deals. Personally I prefer the 2nd one (4350). You might also want a HDMI to DVI adapter for the 2nd screen if you don't want to use the VGA connector and/or your LCD doesn't have HDMI connector.
------------------------------The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
Reply to Zenthar
