I recently bought a new computer build with an asus m4a78- pro which supports hybrid cross fire the onboard is a 3200 and I'm just wondering if there is a way to run it in crossfire with my 4850?
No. Generally you should disable the onboard video if you're going going to use a 4850 and the onboard video doesn't disable itself automatically, as 780G boards can, upon detecting a card other than what it can Hybrid Crossfire with.
------------------------------Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
It should tell you in the mobo manual if it can handle hybrid crossfire, and--if it can--how you go about enabling it. I don't know how much of a performance boost you will get from Hybrid Xfire, but your manual will tell you if it can be done.
