Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > [Solved] [Corsair 850HX PSU] How to detect fan speed and temperature
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - [Solved] [Corsair 850HX PSU] How to detect fan speed and temperature
Best answer from XMSYellowbeard.
How can I detect the fan speed and temperature for the Corsair 850HX power supply? It does not have a 3-pin fan connector. Thanks for the help.
The PSU does a great job of regulating the fan. We worked very hard on all of our PSUs to strike a good balance between cooling and noise.
Sponsored Links
u can see the fan speed with Everest ( tools -> system stability test -> fans).
about the temp, i believe the only way to check it is with a hand thermometer.
Reply to jimishtar
This looks like a great utility. Thank you for the suggestion!
Reply to Kaylani
Everest cannot detect the fan speed of a PSU that does not have a fan header connected to the motherboard.
------------------------------ Official Corsair Tech Support. If You Need Help, Just Ask.
Reply to XMSYellowbeard
I tried Everest. The program is nice, but I guess I'll just have to trust my PSU to do it's job without monitoring since it does not have a fan connector. Thank you both for the help.
Reply to Kaylani
Best answer
It's working great so far so I've not had to monitor it. Thanks for all the responses.
Reply to Kaylani
There are 641 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
