I bought that same Rasa kit and FYI the Rasa block itself is pretty good, Rasa chose to put the pump inside the reservoir, which adds heat because the pump is being cooled in the water flow too adding to the total heat.
Also the pump inside the reservoir creates an electromagnetic field that the water is 100% exposed to, which causes frosting inside the tubing way faster than it should, noticeable with clear distilled water, wouldn't be noticeable with colored fluid, until you drain the system.
Why it happens? I don't have a clue, but it doesn't happen with a pump mounted outside the reservoir, so take that information for what it's worth to you.
That is lesson one of my lessons learned the hard way!
That kit is fully matched, the pump flow rate is not adjustable, it is matched to the radiator and the temps you're getting is basically the best you'll get with that kit.
So adding higher cfm fans to a low cfm designed radiator, won't make much if any difference at all, adding a new dual pass more efficient radiator, adds flow restriction the pump was not designed for.
So bottomline, either be satisfied with what you have, or completely go to a larger water cooling setup, with a superb cooling quad fan radiator w high performance fans, a variable flow quality pump, and an independent reservoir, a system capable of delivering much better temps overall.
You could reuse the water block, as it is the best component of the entire cooling kit.
I'm sorry this is not better news for you, but I've already done the things I've listed testing the Rasa kit, and hopefully my lesson learned the hard way, will at least save you the monetary expense loss of learning the same lesson.
