If I want to use a fan controller to control all my case fans, do the case fans need to be variable rpm/airflow, or does the controller negate the need for that?
Can someone suggest some decent quality 120mm and 140mm fans? No leds please.
Does a controller work for just case fans, or could it work for cpu fans, psu fans, and gpu fans? I'm not sure i'm brave enough to try anything other than case fans.
Thanks for the help so far.
