I am currently planning to upgrade to water cooling for my CPU and GPU to achieve a very quiet system.
I am about to upgrade to 24gb's of RAM which will either be Corsair Dominator 1600 CL9 24gb kit or 6 x Corsair XMS3 1600 CL7 4gb sticks.
My motherboard is a Gigabyte ex58-ds4. (terrible but does the job none the less)
my query is this:
Does ram need airflow to prevent overheating?
Because if the ram is going to overheat I will buy the xms3 so i can attach a waterblock.
or will the heat simply not be an issue?
or should I buy the dominator so the added heat fins can cool the RAM? At the cost of getting CL9?
To be clear I will not use any fans for the entire system except for extremely quiet ones on the biggest radiator I can find for the water cooling.
my query is this:
