Tom's Hardware > Forum > Homebuilt Systems > New System Build > Motherboard 8 pin power connector question.
Forum Homebuilt Systems : New System Build - Motherboard 8 pin power connector question.
I am doing a new build and through research I am aware that my Mobo has two plug ins that are directly from the PSU. there is a 20+4 pin from the PSU that is attached on the right side of the board (if case is stadning up with Mobo installed) and on the top left side there is a 8 pin or 4+4 pin plug. With my PSU I have two cords that can (based on pins alone) be plugged into this plug. Per the purchasing website both of these are included and attached to the PSU unit
1x 4+4-Pin ATX12V/EPS12V Connector
1x 8-pin EPS12V Connector
Based on the labeling of these it leads me to believe that if you use one of the 4 pin sides (for an older/different Mobo) it would be ATX12V or if you use both it would be the same as the other 8 pin cord which is EPS12V. Is it safe to assume that I can use the 8-pin connector and set aside the 4+4 pin connection? Under this assumption the 8 pin wire is not long enough to run behind my Mobo so I have purchased an extension through newegg to add this but I want to be sure I am thinking correctly regarding this. THANKS
ANTEC 1200 Case
Asus p6t Mobo
Rosewill 1000W PSU
Sponsored Links
If your MB has the 8-pin CPU power connector... use the 8-pin plug from the PSU. The 4+4 plug should work as well.
Just be sure NOT to use the 6+2 PCI-E power plugs.
The CPU AUX power plugs will have all the yellow wires on the "clip" side with the black or grounds on the other. PCI-E power plugs are wired the opposite way, grounds are on the "clip" side.
Reply to TheDraac
There are 524 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
