Tom's Hardware > Forum > Homebuilt Systems > New System Build > First build (help please)
Forum Homebuilt Systems : New System Build - First build (help please)
Hey guys, trying to set up my first build and would like some feedback.
Uses: Gaming, Photos, Web surfing, Music
Already have: keyboard, mouse.. have A monitor..
Planned:
WD caviar black 1TB 7200 rpm sata 3gb
evga gtx 260 oc'd
OCZ gold 6 gbs
i7 920 w/plan to oc a little?
evga e758-a1 mobo?
cooler master v8
LG BR/HD dvd-rom
Rosewill RBR750-M psu
Antec 900 case
SAMSUNG Toc T220HD Rose Black 22" 5ms HDMI <----- any recommendations ona new 22" monitor?? This one seems best from my untrained eye
I plan on oc'ng cpu and SLI (in the future). My real hesitancies are on the case with the psu, the psu (rosewill) reliability. And... The mobo, the reviews on newegg seem to be wishy-washy on ALL the recommended boards, but the evga seems to have the least reliability issues...
Thanks a bunch!
EDIT: Sorry, budget is preferred <1800
Message edited by S4L on 06-26-2009 at 07:13:21 PM
Sponsored Links
Whats your budget? Where are you buying from? And no do not get that PSU, get this one instead(someone screwed up newegg pricing so the 550 costs the same as the 650)
http://www.newegg.com/Product/Prod [...] 6817139005
More than enough amps on the 12 Volt rail
Reply to hunter315
< 1800 budget preferred
Newegg seems to have the best deals.
Thanks!
Reply to S4L
get a P6T instead of that EVGA board, it's cheaper and you don't need the extra's that EVGA gives you.
swap the PSU as said to a PCP&C or corsair 750w.
get a 4890 instead of the GTX 260 or get a standard clocked 260.
Oh, and lastly, SLI with a card bought at this time is pointless, since you're spending money on technology that will be obsolete in a few months time. The ATi DX11 cards come out around October with about GTX 295 power in a single GPU at current GTX 275 prices.
Reply to Helloworld_98
The main problem with the EVGA board is the tall heatsinks surrounding the CPU socket area. These get in the way of most of the good coolers. Save a bit there and get the Gigabyte board:
http://www.newegg.com/Product/Comb [...] mbo.203722
Don't read newegg reviews of motherboards, PSUs, or RAM and you'll be better off. People often blame these parts due to a lack of knowledge.
The PSU needs to be avoided. The EA750, which also comes in combo with the case, is a good PSU:
http://www.newegg.com/Product/Comb [...] mbo.197358
If you really wanted modular, this is what I would get at 750W:
http://www.newegg.com/Product/Prod [...] 6817371025
However, once you pay for that with your case, you might as well get the Antec 1200 in combo with it's special very high quality PSU:
http://www.newegg.com/Product/Comb [...] mbo.195790
Which is modular, 850W, but only fits in the 1200 and a few other Antec cases.
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
Thanks for the quick responses guys, really appreciate it.
So this seems to have turned out better and a bit cheaper:
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drives - OEM
Item #: N82E16822136284
Acer H233Hbmid Black 23" 5ms HDMI Full HD 1080P Widescreen LCD Monitor - Retail
Item #: N82E16824009162
XFX HD-489A-ZDFC Radeon HD 4890 1GB 256-bit DDR5 PCI Express 2.0 x16 HDCP Ready Video Card - Retail
Item #: N82E16814150359
Kingston FCR-HS219/1 19-in-1 USB 2.0 Card Reader - Retail
Item #: N82E16820134753
Rosewill RTK-002 Anti-Static Wrist Strap - Retail
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3G1600LV6GK - Retail
Item #: N82E16820227365
Microsoft Windows Vista Home Premium SP1 64-bit for System Builders - OEM
Item #: N82E16832116488
COOLER MASTER V8 RR-UV8-XBU1-GP 120mm Rifle CPU Cooler - Retail
Item #: N82E16835103055
LG Black Blu-ray/HD DVD-ROM & 16X DVD±R DVD Burner SATA Model GGC-H20L - Retail
Item #: N82E16827136133
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail
Antec CP-850 850W Continuous Power CPX SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC "compatible with ... - Retail
Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
GIGABYTE GA-EX58-UD4P LGA 1366 Intel X58 ATX Intel Motherboard - Retail
So, how does THIS sound?? Now, with this being said - I shouldn't need anything else correct. The above listed (excluding mouse and keyboard) should allow me to boot up and begin running programs? I don't need any more fans, tools, duck tape, etc.??
Thanks again for the replies,
Reply to S4L
Thermal paste?
http://www.newegg.com/Product/Prod [...] 6835186020
You really don't need to use Vista.
Just download Windows 7 and run that for now. You can get it from MS technet, you just have to register for instance a hotmail account if you don't have one.
It's free and should be the better OS, with more backwards compatibility than Vista. I need to install mine and give it a whirl soon.
Reply to Proximon
swap the antec 1200 for the P193 if they have a combo of the PSU and case since the P193 looks a bit more normal and has more space inside.
Thanks again Proximon. I just read your guide of parts and its great.
I haven't seen this covered so I feel kind of dumb, but do you need that thermal paste?? Heh...where does it go? How exactly do I go about getting windows 7 on a new computer? Download it to my current one, put it on a disc, then transfer it onto the computer or... Having never done this I don't exactly know what to expect from the set-up without any window's platform, ms-dos? How do you get to the net without windows installed??
Sorry again, I'm sure this is covered somewhere, I just haven't found it..
Reply to S4L
Yes burn Windows 7 to DVD to install it.
Now I realize that the newest editions of Vista come WITH a free upgrade to Windows 7, so that might actually be the better option. Not sure when this started, maybe today?
http://www.newegg.com/Product/Prod [...] 6832116677
Yes, you need thermal paste. The stock cooler has paste pre-applied, but the Xigmatek does not. It goes in-between the cooler and the CPU, to fill in the microscopic air pockets that reduce heat transfer. Only a VERY small amount is used.
Something like this is pretty accurate:
http://www.gwprox.com/pastesize.jpg
I have an old post over in another section that talks about applying paste to a HDT cooler (I use an older version of the Xigmatek.) If you scroll down you'll see a post detailing how I applied Arctic Silver 5... MX-2 would be similar. Look for green text.:
http://www.tomshardware.com/forum/ [...] 1283-e8400
Reply to Proximon
Great info - Thanks for everything Proximon
Reply to S4L
There are 530 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
