Tom's Hardware > Forum > Graphic & Displays > TV/Video Cards > Viewsonic VA2010wb monitor wont turn on!
Forum Graphic & Displays : TV/Video Cards - Viewsonic VA2010wb monitor wont turn on!
I have been using my monitor now for almost a year and it has worked fine untill literally this morning. I was using it this morning, nor problems. I left the cmputer on but turned the screen off to go for a cycle and when i returned 2 hours later, i pressed the button under the screen to turn it back on and it just started flashing the green light on making an odd buzzing.hissing noise.
The screen is not turning on at all and i have tried unplugging it from the wall and the pc. It seems that it has broken, or blown a fuse or something.
Has anyone else had a similar problem, or any suggestions? Thx
Sponsored Links
Welcome to the forums!
Try building outside the computer on cardboard. Sart with mobo, psu, beeper and processsor only. Listen for beeps. Add components and listen for beeps. Add the video card and listen for beeps and look for video.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
You have a problem with the capacitors in the power supply of the monitor. They have leaked and have to be changed. I am a Viewsonic service engineer and I have very big experience with VS monitors. This is a very common problem with this model. If you can not change them, have your monitor serviced by a qualified repairman.
Reply to Anonymous
Get in touch with viewsonic customer service/ technical support. You stated your monitor is ~ a year so its under warranty. They will fix and or repair your monitor.
I have > 2 year old viewsonic display in one of my PCs. A power surge screw it up. One phone call and after 20 days i got a replacement display.
I'm a satisfied customer...
http://www.viewsonic.com/
Reply to leon2006
There are 523 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
  • 01:00 ayeohx won the Freshman badge
