Tom's Hardware > Forum > CPU & Components > Other Components > Mouse Clicking Problem
Forum CPU & Components : Other Components - Mouse Clicking Problem
I'm having issues with my mouse. Before giving the symptoms let me add that I have done the following:
- tried different mouse
- updated mouse driver
- tried different USB port
The issue that I run into is occasionally my mouse buttons stop working. I can still scroll around and my mouse cursors over everything properly, but when I click on things it's not registering. I have found that opening task manager (CtrlAltDel) and then closing it remedies the problem temporarily. Eventually it happens again though.
My concern is that some hardware piece in my computer is not working properly. I have no problem with replacing something, but it's just that I don't know what to replace.
Any advice would be helpful.
Thanks
Sponsored Links
Question: Do you notice this only in your OS (I assume it's Windows) or in other programs as well? If the former, it could be an OS issue as opposed to a hardware one.
Reply to Herr_Koos
- 0 +
It does sound like a OS issue. I had similar problems that I corrected by going into the control panel > Mouse > Hardware > Properties > Advanced settings and changing the polling to 200 per second changing the wheel setting to look for wheel and finally changing the buffer length to 200. This did correct my problem with my mouse. This was done on a system running XP. I believe that the settings can be changed in Vista as well.
------------------------------ http://valid.canardpc.com/cache/banner/490986.png
http://valid.canardpc.com/cache/banner/305006.png
Reply to shabaa
It happens randomly. It does not matter what I am doing (gaming, surfing the net, working in word, etc). I had to "reset" my mouse to click on the reply to you button for instance.
Reply to Vitality
There are 604 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
