WILL A 7200 RPM HARD DRIVE DRIVE WORK IN PLACE OF 5400
WILL A 7200RPM HARD DRIVE OPERATE IN PLACE OF A 5400RPM HD, IF SO WOULD IT BE BETTER
2 answers Last reply
More about will 7200 hard drive drive work place 5400
  1. Yes, and Yes it would be better. Faster is always better, but if you're putting this in a laptop, then faster also means more power being drawn. SSDs are ideal for laptops.
  2. Yes, just make sure they use the same interface; for example SATA I, SATA II or IDE. Also, make sure they are the same size.
Hard Drives HD Storage
