Tom's Hardware > Forum > CPU & Components > Sound Cards > Wave vs Master volume control issue
Forum CPU & Components : Sound Cards - Wave vs Master volume control issue
I have some logitech speakers that up until a few days ago had been running through analog. I am also running these speakers to my tv's receiver through digital coax. I recently got a splitter for the digital coax and now have my computer speakers also connected via coax and now sound much much better. However, apparently that volume control run by the pc is based solely on the wave line out and changing the master line out has absolutely no affect on my speaker volume. The reason why this is problematic is that my keyboard's volume knob changes the Master volume level but not the wave, so my only choice for volume control is through the speaker's console, which is harder to access and not as incremental.
So my question is can anyone think of a way to either have my keyboard control the wave line or have the wave line be affected by the master volume? Or any other solution to this problem? The keyboard is a really old Dell that doesn't have any drivers or anything. Another solution would be a new keyboard with that sort of flexibility if you know of anything.
Thanks!
Sponsored Links
I found this thread while searching for a way to let my keyboard control the wave volume for other purposes... I have my xbox audio running through my computer's line-in to my stereo along with my computer audio. I'd like to be able to use the volume knob on my keyboard to adjust just wave (computer sound, i.e. music) and leave the master at max to be adjusted by the stereo.
Anywho, I managed to find a program called "Volume Tracker" which will map the Master volume settings to the Wave (or any other output) -- essentially linking them together. Not suitable for my application, but it seems that it will work for yours.
You can get it here.
Hope this helps you.
Reply to the eNeME
There are 1257 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
