Here's my previous setup:
ASRock 4CoreDual-Sata2 R2.0
Intel Core2Duo 2.6 (2.4ghz)
Nvidia GeForce 8600 GT (PCI-E)
2, 1gb sticks of DDR2
80 gb maxtor HDD (IDE, CD & DVD drives are IDE as well)
I decided to upgrade to a SATA HDD and purchased a 500gb Western Digital Caviar Green 500AACS hard drive, and an Nvidia GeForce 9500 GT (PCI-E). So today I get everything, decide to not even use this 80gb maxtor drive along with the 500gb WD one, so I replace the old with the new and begin installing win XP with SP3 slip-streamed in so it'll recognize all 500gb of the drive. Everything installs fine and the only thing I installed was a sound driver for my mobo. Keep in mind I still have my old 8600 card hooked up to my monitor and its running on "default" graphics (for lack of a better word) because I havnt yet installed any drivers. I had planned on installing an OS on this HDD and getting *** running before I proceed with replacing the graphics card. So I do this next. I put the 9500 in, hook it up to my monitor using a DVI to VGA adapter, because the 9500 has two DVI ports, and my old 8600 had a VGA port that I connected my monitor to. I try to boot and get no video. Monitor stays on for about 3 mins and then goes from green to orange or "Stand-by" mode if you will. So I put the 8600 back in and install the driver that came with the 9500 along with DirectX. I put the 9500 back in and same thing, no video. Thinking it was a DVI to VGA adapter issue I tried my 8600 with the DVI to VGA adapter and it works fine (the 8600 has a DVI and a VGA port, whereas the 9500 has two DVI ports). I have no idea what could be wrong... only thing I can think of is my mobo not supporting this card, or the 9500 being a PCI 2.0 card while my mobo is described as a PCI-E 1.0 port, info on the 9500 said that it could be used in a PCI-E 1.0 slot... Thanks in advance for any help I'll be waiting around for replies =p
