Hey quick question...i am building a system around an AMD phenom II X4 and im a little puzzled on what case to get.
should i get the Antec 300 that COMES with a power supply...and if you do suggest it, is the power supply good? thats my main concern...is the power supply good
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129065
or should i get the Cooler master 690...seems like a really good case but doesn't come with power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
or are there any other really good cases you would suggest?
