Sound max integrated digital audio driver
hi, i have the problem with sound in windows xp i used windows 7 too but the sound worked properly but in window xp it is not working my sound driver is Sound Max Integrated Digital Audio Driver it downloaded and installed it several times but it's giving the message to restart your pc then the driver will be installed i restarted my pc many times but in vain... plz plz help me with this problem...
Basit...
2 answers Last reply
More about sound integrated digital audio driver
    Basit...
    Which system are you logged into when you do the XP download ?
  2. ------------------
    System Information
    Time of this report: 12/7/2011, 09:19:38
    Machine name: USER
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.060411-1541)
    Language: English (Regional Setting: English)
    System Manufacturer: n/a
    System Model: n/a
    BIOS: n/a
    Processor: Intel(R) Pentium(R) 4 CPU 3.20GHz (2 CPUs)
    Memory: 494MB RAM
    Page File: 531MB used, 625MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.2180 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found.
    Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: Intel(R) 82865G Graphics Controller
    Manufacturer: Intel Corporation
    Chip type: Intel(R) 82865G Graphics Controller
    DAC type: Internal
    Device Key: Enum\PCI\VEN_8086&DEV_2572&SUBSYS_2026107B&REV_02
    Display Memory: 96.0 MB
    Current Mode: 1024 x 768 (32 bit) (85Hz)
    Monitor: Plug and Play Monitor
    Monitor Max Res: 1600,1200
    Driver Name: ialmrnt5.dll
    Driver Version: 6.14.0010.4363 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 4/1/2006 11:33:22, 38014 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp: n/a
    VDD: n/a
    Mini VDD: ialmnt5.sys
    Mini VDD Date: 4/1/2006 11:33:22, 1049180 bytes
    Device Identifier: {D7B78E66-6632-11CF-C062-2C00A3C2CB35}
    Vendor ID: 0x8086
    Device ID: 0x2572
    SubSys ID: 0x2026107B
    Revision ID: 0x0002
    Revision ID: 0x0002
    Video Accel:
    Deinterlace Caps: n/a
    Registry: OK
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Not Available
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
    Sound Devices
    Description:
    Default Sound Playback: No
    Default Voice Playback: No
    Hardware ID:
    Manufacturer ID:
    Product ID:
    Type:
    Driver Name:
    Driver Version:
    Driver Attributes:
    WHQL Logo'd:
    Date and Size:
    Other Files:
    Driver Provider:
    HW Accel Level: Emulation Only
    Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Registry: OK
    Sound Test Result: Not run
    Sound Capture Devices
    DirectMusic
    DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
    DLS Version: 1.00.0016.0002
    Acceleration: n/a
    Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
    Registry: OK
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Poll w/ Interrupt: No
    Registry: OK
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x8086, 0x24D4
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 3/5/2006 19:40:32, 57984 bytes
    | Driver: usbd.sys, 8/4/2004 18:00:00, 4736 bytes
    Gameport Devices
    PS/2 Devices
    + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 8/4/2004 18:00:00, 52736 bytes
    | Driver: kbdclass.sys, 8/4/2004 18:00:00, 24576 bytes
    + Microsoft PS/2 Mouse
    | Matching Device ID: *pnp0f03
    | Service: i8042prt
    | Driver: mouclass.sys, 7/6/2006 13:50:16, 23040 bytes
    DirectPlay Service Providers
    DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
    Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
    Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
    DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
    DirectPlay Test Result: Not run
    Registry: OK
    DirectPlay Adapters
    DirectPlay8 Serial Service Provider: COM1
    DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
    DirectPlay Voice Codecs
    Voxware VR12 1.4kbit/s
    Voxware SC06 6.4kbit/s
    Voxware SC03 3.2kbit/s
    MS-PCM 64 kbit/s
    MS-ADPCM 32.8 kbit/s
    Microsoft GSM 6.10 13 kbit/s
    TrueSpeech(TM) 8.6 kbit/s
    DirectPlay Lobbyable Apps
    System Devices
    Name: Intel(R) 82865G/PE/P/GV/82848P Processor to PCI to CSA bridge - 2573
    Device ID: PCI\VEN_8086&DEV_2573&SUBSYS_00000000&REV_02\3&267A616A&0&18
    Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2585 (English), 10/17/2005 22:36:26, 68224 bytes
    Name: Intel(R) 82865G Graphics Controller
    Device ID: PCI\VEN_8086&DEV_2572&SUBSYS_2026107B&REV_02\3&267A616A&0&10
    Driver: C:\WINDOWS\system32\DRIVERS\ialmnt5.sys, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 1049180 bytes
    Driver: C:\WINDOWS\system32\ialmrnt5.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 38014 bytes
    Driver: C:\WINDOWS\system32\ialmdnt5.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 116859 bytes
    Driver: C:\WINDOWS\system32\ialmdev5.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 212090 bytes
    Driver: C:\WINDOWS\system32\ialmdd5.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 899706 bytes
    Driver: C:\WINDOWS\system32\igxpxa32.cpa, 4/1/2006 11:33:26, 524850 bytes
    Driver: C:\WINDOWS\system32\igxpxa32.vp, 4/1/2006 11:33:26, 900 bytes
    Driver: C:\WINDOWS\system32\igxpxk32.vp, 4/1/2006 11:33:28, 58675 bytes
    Driver: C:\WINDOWS\system32\igxpxs32.vp, 4/1/2006 11:33:28, 18496 bytes
    Driver: C:\WINDOWS\system32\hccutils.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 73728 bytes
    Driver: C:\WINDOWS\system32\igfxsrvc.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 57344 bytes
    Driver: C:\WINDOWS\system32\igfxsrvc.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 159744 bytes
    Driver: C:\WINDOWS\system32\igfxpph.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 147456 bytes
    Driver: C:\WINDOWS\system32\igfxcpl.cpl, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 77824 bytes
    Driver: C:\WINDOWS\system32\igfxcfg.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 438272 bytes
    Driver: C:\WINDOWS\system32\igfxdev.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 135168 bytes
    Driver: C:\WINDOWS\system32\igfxdo.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 86016 bytes
    Driver: C:\WINDOWS\system32\igfxtray.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 163840 bytes
    Driver: C:\WINDOWS\system32\igfxzoom.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 114688 bytes
    Driver: C:\WINDOWS\system32\hkcmd.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 155648 bytes
    Driver: C:\WINDOWS\system32\igfxress.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 1503232 bytes
    Driver: C:\WINDOWS\system32\igfxpers.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 114688 bytes
    Driver: C:\WINDOWS\system32\igfxrara.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 122880 bytes
    Driver: C:\WINDOWS\system32\igfxrchs.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 81920 bytes
    Driver: C:\WINDOWS\system32\igfxrcht.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 81920 bytes
    Driver: C:\WINDOWS\system32\igfxrdan.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
    Driver: C:\WINDOWS\system32\igfxrdeu.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 155648 bytes
    Driver: C:\WINDOWS\system32\igfxrenu.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 135168 bytes
    Driver: C:\WINDOWS\system32\igfxresp.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 151552 bytes
    Driver: C:\WINDOWS\system32\igfxrfin.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
    Driver: C:\WINDOWS\system32\igfxrfra.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 147456 bytes
    Driver: C:\WINDOWS\system32\igfxrheb.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 118784 bytes
    Driver: C:\WINDOWS\system32\igfxrita.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 151552 bytes
    Driver: C:\WINDOWS\system32\igfxrjpn.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 98304 bytes
    Driver: C:\WINDOWS\system32\igfxrkor.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 98304 bytes
    Driver: C:\WINDOWS\system32\igfxrnld.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 147456 bytes
    Driver: C:\WINDOWS\system32\igfxrnor.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
    Driver: C:\WINDOWS\system32\igfxrplk.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
    Driver: C:\WINDOWS\system32\igfxrptb.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
    Driver: C:\WINDOWS\system32\igfxrptg.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
    Driver: C:\WINDOWS\system32\igfxrrus.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
    Driver: C:\WINDOWS\system32\igfxrsve.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
    Driver: C:\WINDOWS\system32\igfxrtha.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 126976 bytes
    Driver: C:\WINDOWS\system32\igfxrcsy.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 139264 bytes
    Driver: C:\WINDOWS\system32\igfxrell.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 155648 bytes
    Driver: C:\WINDOWS\system32\igfxrhun.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 143360 bytes
    Driver: C:\WINDOWS\system32\igfxrtrk.lrc, 3.00.0000.4363 (English), 4/1/2006 11:33:24, 135168 bytes
    Driver: C:\WINDOWS\system32\igfxext.exe, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 98304 bytes
    Driver: C:\WINDOWS\system32\igfxexps.dll, 3.00.0000.4363 (English), 4/1/2006 11:33:22, 36864 bytes
    Driver: C:\WINDOWS\system32\ialmrem.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:22, 49152 bytes
    Driver: C:\WINDOWS\system32\iglicd32.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:26, 2310144 bytes
    Driver: C:\WINDOWS\system32\igldev32.dll, 6.14.0010.4363 (English), 4/1/2006 11:33:24, 524288 bytes
    Driver: C:\WINDOWS\system32\ialmudlg.exe, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 114688 bytes
    Driver: C:\WINDOWS\system32\ialmuARA.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuARB.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuCHS.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuCHT.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuCSY.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuDAN.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuDEU.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuELL.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuENG.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuESP.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuFIN.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuFRA.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuFRC.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuHEB.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuHUN.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuITA.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuJPN.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuKOR.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuNLD.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuNOR.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuPLK.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuPTB.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuPTG.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuRUS.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuSVE.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuTHA.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\ialmuTRK.dll, 0.00.0000.0000 (English), 4/1/2006 11:33:22, 40960 bytes
    Driver: C:\WINDOWS\system32\iAlmCoIn_v4363.dll, 1.00.1000.0001 (English), 4/1/2006 11:33:22, 61440 bytes
    Name: Intel(R) 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
    Device ID: PCI\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\3&267A616A&0&00
    Driver: n/a
    Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
    Device ID: PCI\VEN_8086&DEV_24DE&SUBSYS_2026107B&REV_02\3&267A616A&0&EB
    Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2891 (English), 6/17/2006 22:43:54, 20608 bytes
    Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2891 (English), 7/6/2006 12:43:06, 143360 bytes
    Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:48, 74240 bytes
    Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2846 (English), 3/5/2006 19:40:32, 57984 bytes
    Name: Intel(R) 82801EB USB2 Enhanced Host Controller - 24DD
    Device ID: PCI\VEN_8086&DEV_24DD&SUBSYS_2026107B&REV_02\3&267A616A&0&EF
    Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2891 (English), 6/17/2006 22:43:54, 30080 bytes
    Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 18:00:00, 7168 bytes
    Name: Intel(R) 82801EB Ultra ATA Storage Controllers - 24DB
    Device ID: PCI\VEN_8086&DEV_24DB&SUBSYS_2026107B&REV_02\3&267A616A&0&F9
    Driver: C:\WINDOWS\system32\DRIVERS\intelide.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:42, 5504 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/4/2004 18:00:00, 25088 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/4/2004 01:59:44, 95360 bytes
    Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
    Device ID: PCI\VEN_8086&DEV_24D7&SUBSYS_2026107B&REV_02\3&267A616A&0&EA
    Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
    Device ID: PCI\VEN_8086&DEV_24D4&SUBSYS_2026107B&REV_02\3&267A616A&0&E9
    Name: Intel(R) 82801EB SMBus Controller - 24D3
    Device ID: PCI\VEN_8086&DEV_24D3&SUBSYS_2026107B&REV_02\3&267A616A&0&FB
    Driver: n/a
    Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
    Device ID: PCI\VEN_8086&DEV_24D2&SUBSYS_2026107B&REV_02\3&267A616A&0&E8
    Name: Intel(R) 82801EB Ultra ATA Storage Controllers - 24D1
    Device ID: PCI\VEN_8086&DEV_24D1&SUBSYS_2026107B&REV_02\3&267A616A&0&FA
    Name: Intel(R) 82801EB LPC Interface Controller - 24D0
    Device ID: PCI\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\3&267A616A&0&F8
    Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/4/2004 18:00:00, 35840 bytes
    Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\3&267A616A&0&F0
    Name: Intel(R) PRO/1000 CT Network Connection
    Device ID: PCI\VEN_8086&DEV_1019&SUBSYS_2026107B&REV_00\4&26062112&0&0818
    Driver: C:\WINDOWS\system32\DRIVERS\e1000325.sys, 8.05.0014.0000 (English), 4/1/2006 11:33:08, 177152 bytes
    Driver: C:\WINDOWS\system32\Prounstl.exe, 8.00.0007.0000 (English), 4/1/2006 11:33:10, 126976 bytes
    Driver: C:\WINDOWS\system32\e1000325.din, 4/1/2006 11:33:16, 2745 bytes
    Driver: C:\WINDOWS\system32\IntelNic.dll, 8.02.0009.0000 (English), 4/1/2006 11:33:28, 23040 bytes
    Driver: C:\WINDOWS\system32\e1000msg.dll, 8.05.0012.0000 (English), 4/1/2006 11:33:16, 163840 bytes
    Driver: C:\WINDOWS\system32\EtCoInst.dll, 2.02.0001.0000 (English), 4/1/2006 11:33:08, 17408 bytes
    DirectX Components
    ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 266240 bytes
    ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 27136 bytes
    dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 10496 bytes
    d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 1179648 bytes
    d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 8192 bytes
    d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 1689088 bytes
    d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 436224 bytes
    d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 825344 bytes
    d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 590336 bytes
    d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 350208 bytes
    d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 47616 bytes
    d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 34816 bytes
    dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 18:00:00 33040 bytes
    dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 229888 bytes
    dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 23552 bytes
    dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 18:00:00 42768 bytes
    dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 57344 bytes
    dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 30208 bytes
    dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 18432 bytes
    dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 375296 bytes
    dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 3584 bytes
    dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 3584 bytes
    dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 212480 bytes
    dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 83456 bytes
    dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 116736 bytes
    dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 21504 bytes
    dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 35328 bytes
    dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 60928 bytes
    dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 18:00:00 53520 bytes
    dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 159232 bytes
    dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 181760 bytes
    dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 44032 bytes
    diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 394240 bytes
    joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 68608 bytes
    gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 18:00:00 76800 bytes
    pid.dll: 5.03.2600.2180 English Final Retail 7/6/2006 13:50:16 35328 bytes
    dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 367616 bytes
    dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 1294336 bytes
    dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 19456 bytes
    dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 181760 bytes
    dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 71680 bytes
    dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 104448 bytes
    dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 28672 bytes
    dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 61440 bytes
    dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 181248 bytes
    dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 35840 bytes
    dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 105984 bytes
    dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 103424 bytes
    dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 82432 bytes
    dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 619008 bytes
    dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 1227264 bytes
    dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 2113536 bytes
    mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 18:00:00 924432 bytes
    mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 18:00:00 1028096 bytes
    wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 18:00:00 22528 bytes
    amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 70656 bytes
    devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 59904 bytes
    dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 18:00:00 498205 bytes
    mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 35328 bytes
    mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 148992 bytes
    msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 14336 bytes
    encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 20480 bytes
    qasf.dll: 11.00.5358.4827 English Final Retail 5/30/2006 22:11:06 201728 bytes
    qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 192512 bytes
    qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 279040 bytes
    qdvd.dll: 6.05.2600.2831 English Final Retail 2/19/2006 05:01:10 386048 bytes
    qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 562176 bytes
    qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 733696 bytes
    quartz.dll: 6.05.2600.2905 English Final Retail 6/17/2006 22:43:52 1287680 bytes
    strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 18:00:00 246302 bytes
    iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 18:00:00 199680 bytes
    ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 18:00:00 848384 bytes
    ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 18:00:00 120320 bytes
    ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 18:00:00 338432 bytes
    ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 18:00:00 755200 bytes
    ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 18:00:00 200192 bytes
    ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 18:00:00 183808 bytes
    ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 18:00:00 154624 bytes
    mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 204288 bytes
    ks.sys: 5.03.2600.2818 English Final Retail 12/28/2005 21:29:30 141056 bytes
    ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
    ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
    stream.sys: 5.03.2600.2790 English Final Retail 11/4/2005 21:55:10 48768 bytes
    mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
    mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
    mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
    swenum.sys: 5.03.2600.2180 English Final Retail 7/6/2006 13:50:16 4352 bytes
    mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 118272 bytes
    msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 18:00:00 1428480 bytes
    vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 30720 bytes
    msyuv.dll: 5.03.2600.2180 English Final Retail 7/6/2006 13:50:16 17408 bytes
    wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 18:00:00 50688 bytes
    DirectShow Filters
    DirectShow Filters:
    WMAudio Decoder DMO,0x00800800,1,1,,
    WMAPro over S/PDIF DMO,0x00600800,1,1,,
    WMA Voice Decoder DMO,0x00600800,1,1,,
    WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
    Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2905
    DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
    Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2905
    WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5358.4827
    AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2905
    WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2905
    Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
    Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
    WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
    WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
    Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
    WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2905
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
    MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
    ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2905
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2905
    File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5358.4827
    WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
    Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2905
    Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
    WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5358.4827
    NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2905
    Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5358.4827
    Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2905
    Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2831
    Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2905
    WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
    Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2905
    WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5358.4827
    WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
    Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
    File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
    WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
    DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2831
    Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2831
    AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2905
    .RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5358.4827
    WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
    Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
    Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5358.4827
    ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5358.4827
    9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
    Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
    Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
    WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
    WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
    Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2831
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
    Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2905
    QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2905
    Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
    MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2905
    File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2905
    XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5358.4827
    AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2905
    File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2905
    File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2905
    WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
    QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2905
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2905
    Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
    Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
    WDM Streaming Data Transforms:
    Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
    Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
    Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
    Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
    Video Compressors:
    MSScreen encoder DMO,0x00600800,1,1,,
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
    Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2905
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
    Audio Compressors:
    WMA Voice Encoder DMO,0x00600800,1,1,,
    WMAudio Encoder DMO,0x00600800,1,1,,
    IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2905
    IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2905
    Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2905
    ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2905
    DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2905
    Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2905
    Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2905
    GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2905
    Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2905
    CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2905
    CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2905
    MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2905
    Midi Renderers:
    Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2905
    WDM Streaming Mixer Devices:
    Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
    BDA CP/CA Filters:
    Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
    Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
    XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
    Audio Renderers:
    Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2905
    Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2905
    these are my system requirements. i m using Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp.060411-1541)....
Drivers Audio Windows XP
