Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > [Solved] 4770 or 4850 with limited power supply help!!
Forum Graphic & Displays : Graphics Cards - [Solved] 4770 or 4850 with limited power supply help!!
Best answer from Jaysin.
Hi all,
I have been going back and forth on this one. I hope you guys can help me out. Like many others, I have been debating whether to get a Radeon 4770 or a 4850. Im leaning towards the 4850 right now because it is the same price but performs slightly better. The problem is, I only have a 400w (cheap) power supply, and the 4770 uses much less power.
Currently I am already running on this ps:
Asus M4a78t-e mobo
phenom II 3x 720
2x2gb ddr2 1333 ram
2 80mm case fans
WD hard drive
Optical Drive
My question is, given my limited power supply, is it a better decision for me to go with the 4770 due to its lower power usage? Or is 400w plenty enough to run a 4850 safely.
Thanks in advance for your expertise.
Not much, still stick with the HD4770. The performance difference is negligible compared to the cost of getting a new power supply to use the 4850 comfortably.
Sponsored Links
Go with the Hd 4770.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
My bad, its actually ddr3 ram. I don't know if that actually makes a difference though.
Reply to kevindemand
Best answer
Reply to Jaysin
^+1
------------------------------ Peace cannot be kept by force, it can only be achieved by understanding: Eienstien
Reply to coozie7
ive seen 4870s priced around where 4850s should be. and of course, the 4870 is vastly superior to the 4850. needs more juice too tho, so i guess im just busting your balls in the end.
Reply to neon neophyte
Hey guys, thanks for your input. I think i will get the 4770, and crossfire it when I upgrade to a better power supply in the future.
There are 825 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
