Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Help - Graphics or Moniter? - Help
Forum Graphic & Displays : Graphics Cards - Help - Graphics or Moniter? - Help
Hi,
i've had my pc for about 2 months everything was working perfectly until my moniter (hp vs17) suddenly got no signal from my graphics card (ati 4670 1gb) and my pc started booting from my prevousily disabled onboard graphics card. my moniter only has a vga port and my graphics card uses only a dvi-I so i use an adaptor.
is the problem my adapter vga to dvi, my graphics card, moniter, motherboard, the pc booting from wrong card??? Please help
Sponsored Links
Try removing, then reinserting the video card.
You can rule out the monitor and the adapter if the monitor works hooked up to the motherboard graphics. Try the graphics card in a different computer if possible. Check your power supply.
Reply to festerovic
set your pc to boot up from PCIe (PEG in the BIOS)
Reply to Shnur
There are 497 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
